Is the TF536 you guys on using on these the new Exxos modded version? ST version? or is it the original?
I have a TF536 but I was under the impression that the exxos modded version was much better to use? I do have a TF534 as well.. the extra memory really is not needed but can a TF534 be used as well?
Is the decoder being sold DOG?
DoG's H5 C1 Build
Re: DoG's H5 C1 Build
@Bikerbob I'm using the original (V2?) TF536 with mine (there's a different CPLD image for the ST), though I hope to upgrade to the ST version when the CPLDs are available.
The ST version by Exxos includes the decoder for TOS 2.06 etc. but the IDE is not working.
If DoG isn't selling his decoder then Exxos has his version in the store.
Please let us know what you decide to do!
The original TF536 only runs faster with the extra RAM. If you're not using the ram, then adding the original TF536 will add nothing to your system.
DoG
I bought one of the first TF536 PhilC built up for the ST (original card). It got ST firmware on it (programmed by PhilC) but I think that got developed a bit further by aGranlund after that.Bikerbob wrote: 06 Aug 2021 04:19 Is the TF536 you guys on using on these the new Exxos modded version? ST version? or is it the original?
My decoder board is not being sold since I don't want to compete with exxos when he got sort of the same products for sale and I'm on his 'Turf'.
DoG
Did the Audio fix needed. Scratched a bit out of the ground plane and used a 100K 0805 SMD resistor and the other end to the VIA attached to the resistor with the signal YM_AUDIO.
Users browsing this forum: CCBot and 188 guests
