Working good on my STFM...... I think there is some irony in this somewhere with the not working on the H4 :lol: :roll:
Still going :)
Left it on all night with ultrasatan plugged in. GB6 outputs the lopo count and time into a text file every loop (what a awesome feature! :lol: ) So US gets tested the entire time writing to it...
So its basically been turned on for 24H pretty much now.
derkom
I always wished it would put the current loop number up in the menubar, so if you're looking at live output, you don't have to wait for the end of a loop to know how far it's gotten.exxos wrote: 18 Jan 2020 10:58 GB6 outputs the lopo count and time into a text file every loop (what a awesome feature! :lol: )
I have had the same thought in the past actually :) Though its why the screen flashes red when it displays the loop count to get my attention ;)derkom wrote: 18 Jan 2020 19:36 I always wished it would put the current loop number up in the menubar, so if you're looking at live output, you don't have to wait for the end of a loop to know how far it's gotten.
just tried updating the firmware with version 3/3 and my H4 doesn't boot at all.
@PhilC - try it with a 32MHz osc and see what happens :)
Yeah just remembered what you said in the email. It boots with the 32mhz oscillator.
Still bombs with a floppy in at boot though, or when I try to access a disk at the desktop.
It seems to get stuck at busy bee for longer than it should when loading the desktop
Just re read @Icky email from the other day and his H4 works at 32mhz and boots but mine crashes on floppy access.
U had a bad DMA problem exactly like this on one of my Megas, so I think its time to swap a few parts out and see if that improves matters.
Will report back later.
Have no idea why it won't work for your guys. Probably have to wait until I get my H4 to look into it. Hardly had any issues here, but TOS206 does seem to need a few resests on the reset switch to boot, but i've not really looked into that issue yet, might be just iffy reset on my board.
Ok, will try it in an STFM this week
