@PhilC Once you done this https://www.exxosforum.co.uk/forum/viewt ... 893#p31893 and you get your SEC booster running (ask @Icky for images how to fit it to the H4
) See if ultrasatan and the floppy drive behave. Icky can't get ultrasatan working correctly with the SEC installed. Though its all currently working fine on my STFM here.
https://www.exxosforum.co.uk/atari/ All my hardware guides - mods - games - STOS
https://www.exxosforum.co.uk/atari/store2/ - All my hardware mods for sale - Please help support by making a purchase.
viewtopic.php?f=17&t=1585 Have you done the Mandatory Fixes ?
Just because a lot of people agree on something, doesn't make it a fact. ~exxos ~
People should find solutions to problems, not find problems with solutions.
@exxos will do. Will start with a good STFM and once that works, move on to the H4.
After discussing with @exxos it seemed to be the Blitter causing the issue. After removing Blitter the floppy and UltraSATAN works together. However am still having issues with Gigafile.
@PhilC - just go straight for the H4. It’s a very easy install.
Will do @IckyIcky wrote: Wed Jan 15, 2020 7:18 am After discussing with @exxos it seemed to be the Blitter causing the issue. After removing Blitter the floppy and UltraSATAN works together. However am still having issues with Gigafile.
It be interesting what speed you get with tos206 with glitter as I've still got slower than expected speeds on my stfm. I get 175% first test but the ste is 181% but as ROM is faster on the sec the speeds should be more like 190%.
Been doing a lot of tweaks. Getting TOS104, TOS206, BLITTER, ULTRASATAN all to play nice is a nightmare.
Mostly , for some odd reason, TOS104 I need to wait for ST_DTACK to go high before allowing any ROM decoding to happen. TOS206 doesn't seem to care.. Without that sync delay, TOS104 resets when accessing C: drive, TOS206 doesn't. ROM speed has dropped a bit, but still at 309%. First GB6 test has dropped from 172% to 163%... will fiddle more tomorrow.
This isn't a very exciting test.. But I kept reducing the DTACK pull up (about 434R now!) To see what would happen, and the figures have gone up ever so slightly..
I think what the problem is in terms of ROM speed access, is that because ST_DTACK is so slow, I have to wait for it to go high before I let the CPU read DTACK as issued by the PLD logic. Otherwise the CPU reads the end of the ST_DTACK cycle and completes ROM access a lot sooner, normally before ROM is even ready.
A edit to the ROM code and we jump to 345%. I think thats as good as its ever going to get.
I removed my DTACK resistors and got 164% first test, and it crashed on the second test
Either way DTACK will likely need a lower value to gain the extra speed.
Next to try about 600R on ST_DTACK.. First GB6 test 163% and ROM speed is 309% again. So seems 400R is needed , thats a little low really.
more to come later...
My board arrived today, hope to test it out tomorrow.
Great @PhilC. I just posted a guide on how to install here - https://www.exxosforum.co.uk/forum/viewt ... =78&t=2466
You can replace the ROM on the H4 with the 104/206 one you have on your IDE DEV board to take advantage of TOS 206.
Will be interesting to see how yours behaves compared to mine on the H4.
@Icky yes thanks for posting that. I'll have a go a bit later on. Hopefully fix the SMT board too whilst I'm at it.
