:o)
Information and news about the 68SEC000 64MHz booster.
:cheer: :cheer: :cheer: :cheer: :cheer: :cheer: :cheer: :cheer: :cheer:
40MHz this test.. 40MHz CPU & 40MHZ Fast-rom with TOS206 :D :D
Now to bring back up 50MHz speeds.....
Looking great. Isn't that already faster than the 40mhz v1.5 ste booster that I have? Looking forward to seeing 50mhz
Forgottenmyname wrote: 25 Jan 2019 21:48 Looking great. Isn't that already faster than the 40mhz v1.5 ste booster that I have? Looking forward to seeing 50mhz
Its probably a bit faster yes. Though this isn't running with the blitter, so its not exactly a fair comparison to the STE booster speeds on this benchmark... Will add the blitter and re-test once I have 50MHz running again.
And once you're finished I can break it by putting it in my Mega :lol:
Oddly (again) TOS104 works at 50MHz but TOS206 does not...
.. and yet, TOS206 works at 40MHz.. bizzare...
Also my highest score of 506% on int-div!
Not been able to figure out TOS206 not working at 50MHz, but some progress made at least today!
Oddly I still get that I7 bus error thing with the diagnostic cartridge :shrug:
exxos wrote: 25 Jan 2019 23:04 Not been able to figure out TOS206 not working at 50MHz, but some progress made at least today!
Keep up the good work that elusive stable 50MHz will be there soon.
I don't get the I7 error when running 8MHz...
I wonder if when the CPU sees BERR from the GLUE, it does whatever it normally does to fast, then re-reads BERR and locks up totally.. Or for some reason ST_DTACK is still low when GLUE issues BERR and it confuses the CPU... But that would be tricky to figure out.. I guess I will have to read up on how BERR all works again..
I've opened a new topic for the PAK as it has nothing to do with this thread, https://www.exxosforum.co.uk/forum/viewt ... 571#p17262
There is still a bit of a mystery going on.. As the only change in the current code was to tristate LDS,UDS,RW on BGACK. Now the cpu does that itself anyway, but obviously routing those lines via the pld has improved things. I can only think that the delay is helping solve the issues. So I will try delaying the signals more tomorrow when I get home and see if TOS 206 boots at 50mhz...
As to why the TOS version matters is a bit odd. I'm going on the thought that 206 uses BERR in the start up code somewhere which 104 isn't doing. Also emutos still doesn't start but that reports bus error.
My next thought is the CPU tries to terminate the berr , but then re-reads berr from glue and tries to repeat the cycle causing the error. So I suspect berr does work, but the cpu tries the cycle twice and screws up causing the berr to appear its not worked.. Matter of perspective I guess..
Problem is, berr is based on the glue running 8mhz. So with the speed of the cpu running at 50mhz it could see berr several times. Which is my best guess to what is going on. Of course the system all works when running at 8mhz, so there is no fault anyway, its relating to fast cpu only.
The only possible solution I see is to run the CPU at 8mhz during a berr cycle. Now I got my new board built I can add in the clock switching .. I just need to tag a berr wire to the pld to switch to 8mhz :roll: I guess ultimately I need to sync berr via the pld as well...
So a lot more tests to do.. At least the end of my booster research is finally looking like the end is near! So I need to prove the idea, then start on version 3 of then board.. Maybe that will be closer to a final design!
Return to “SEC 64MHZ BOOSTER”
