Information and news about the 68SEC000 64MHz booster.
Forgottenmyname wrote: 19 Jan 2019 11:23 Is the Atmel programmer the same as for the atmega328 etc? As I have one of those somewhere
It needs to program the ATF15xx series..
Ok, can you not do those with a tl866? They are just a gal equivalent right?
Forgottenmyname wrote: 19 Jan 2019 14:35 Ok, can you not do those with a tl866? They are just a gal equivalent right?
These chips are like 100pin using JTAG. Totally different programming tech than gals. You have to use the correct jtag programmer by atmel.
Ok, it's neither of the two i've got as i doubt the Kies one i got will.
PaulJ
Post by PaulJ »
A eetools chipmax2 will do them. It pretty much does anything...
rpineau
Post by rpineau »
The chipmax2 doesn't .. it does the ATF16/20/22Vxx, ATV750/1500/2500 .. but not the ATF15xx which have their proprietary algo. They require a specific programmer , the ATDH1150USB (which as you can imagine only does these and nothing else).
The ATF15xx family : http://ww1.microchip.com/downloads/en/D ... erview.pdf
The ATDH1150USB :
https://www.microchipdirect.com/product/ATDH1150USB
https://www.digikey.com/product-detail/ ... ND/2050869
https://www.mouser.com/ProductDetail/Mi ... UebQ%3D%3D
https://uk.farnell.com/microchip/atdh11 ... dp/2695292#
been there, done that ...
thats a bit more affrordable, the other was like £424, instread of £50
Can stretch to one of those next month :D
PaulJ
Post by PaulJ »
rpineau wrote: 19 Jan 2019 17:38 The chipmax2 doesn't .. it does the ATF16/20/22Vxx, ATV750/1500/2500 .. but not the ATF15xx which have their proprietary algo. They require a specific programmer , the ATDH1150USB (which as you can imagine only does these and nothing else).
The ATDH1150USB :
I beg to differ.. see screen shot of selections. If its listed it programs the device. Never had one that was listed not work. Maybe you have old info or old software?. Not sure if I have the adaptor but that's secondary to the programmer being capable.
Excuse the crappy pic but I couldn't find the snipper on windoze and didn't want to waste any time on it. I use it as a hammer and only use it when absolutely necessary,,
How does the programmer interface to the ATF15xx series ? must have JTAG cable?, as inserting the SMT TQFN package be near impossible into the programmer..
PaulJ
Post by PaulJ »
There a column that lists adaptors, I have some but haven't checked the the adaptor specified. It also burns the cplds for bf's boards but I'm going to use the Raspberry so I can check them after soldering as his video shows.
Return to “SEC 64MHZ BOOSTER”
