H5C1- firST STeps
Re: H5C1- firST STeps
Post by JezC »
Well, I just tried re-soldering some of the connections on the GLUE socket (4 or 5 looked a bit iffy)...but sadly that's not fixed it.
I'll re-test with the diag cart tomorrow & see if the errors reported are the same or not...if it's the same then I'd better dig out the schematics & see which connections might be faulty & causing the bus fault (especially with which address lines are required for the floppy accesses).
Post by JezC »
Yet more steps backwards on this...though the H5 is no better off, I've managed to damage the H4 somehow (possibly when testing the other keyboard, floppy drive/cable & PSU) so that won't power up now - no power LED on the keyboard, so I've probably managed to short something.
Even with all the other parts re-instated the H4 won't boot (but I've tried everything bar the floppy cable on the H5 & that is the same with all of them, so it appears to be the H4 board itself :( )...and with just the working PSU it still doesn't seem to boot.
I'll have to bell out the power & ground planes to see if I can locate the issue...ho hum.
Hope to get chance to look further into this over the Bank Holiday weekend...
Post by JezC »
Dug out my multi-meter & the H4 is showing ~0.7 ohms between GND & 5V (no keyboard, PSU or floppy connected, so just the H4 board and ICs fitted).
The H5 by comparison reads ~164 ohms, so that would explain the PSU not powering up into a near dead-short!
Since this H4 board was previously working, I'm hoping it's either something bridging across the supplies on the outer layers or a dead IC or similar.
Now all I need is the time to start investigating...
Post by JezC »
Yes, way beyond what my Fluke can do...I'll check if they have something similar at work (but I'm not sure if they do).
I've pulled all the socketed chips,SIMM module etc. & the short is still there :(
Probably time to start looking at the schematics to see where there might be a short.
EDIT: I'll start adding these H4 diagnostic steps to the old H4 build topic rather than confuse this H5 one...
Post by JezC »
Inspired in part by @exxos having some of the RasPi Pico-based hard drives in stock again, I'm going to try and connect up the logic analyser to the H5 & see if that shows something re the bombs on accessing the floppy...
Can any kind soul point me to the schematics for the H5C1 - I know I've seen them at some point in the past (or though I had)...but as usual when I actually want to use them they are hiding somewhere...
Don't think I have uploaded the C1 yet, but basically same as rev A anyway viewtopic.php?f=89&t=3457
viewtopic.php?f=89&t=6524
Post by JezC »
exxos wrote: 14 Sep 2023 17:48 Don't think I have uploaded the C1 yet, but basically same as rev A anyway viewtopic.php?f=89&t=3457
Thanks @exxos - now that is one less excuse I can use for not getting the H5C1 working.... :lol: :roll:
JezC wrote: 14 Sep 2023 21:06 Thanks @exxos - now that is one less excuse I can use for not getting the H5C1 working.... :lol: :roll:
Yes we need to know what the problem is! :chairsmack:
Looking back you seem to get bus errors from the diagnostic cartridge which is pretty bizarre as I will be more a CPU type fault.
Did you run RAM test from the cart and leave it running for a hour ?
Also if you can run floppy check on the diagnostic cartridge, have you looked to see the physical drive heads are moving and the disc is actually rotating etc ?
Looking back you posted this..
But SIDE 8 ?!
JezC wrote: 21 Aug 2021 11:08 Floppy test failed, see below
Disk A: DS
Formatting Side 8 Track 00
EB Bus Error Access Address: 4E4E58 Program Counter: 3B001F
EA Address Error Access Address: 3B001F Program Counter: FA0E88
EA Address Error Access Address: FD3FFB Program Counter: FABE8A
EA Address Error Access Address: 00386D Program Counter: FAGESC
Return to “H5 C1 USER BUILDS”
