General Stuff(tm)
Re: General Stuff(tm)
stephen_usher wrote: Sun Oct 09, 2022 8:17 am I’ve ordered another add board for the RGB2HDMI, £35 quid via SellMyRetro.
Our hobby is an expensive one when things go wrong. Just read this thread and something you would never expect to see 25V p-p in these machines.
Glad it’s not fried the lot.
mrbombermillzy
Post by mrbombermillzy »
That was really bad luck. :(
Like you say though, it could have been worse.
An expensive thing to have to replace, but it could have been a lot worse I guess.
Also good to show other people this sort of thing can happen to anybody.
The replacement 12 bit board for the RGB2HDMI arrived today and thankfully that's fixed the problem. *phew!*
The main board is getting problematic due to it using a CPLD.
Designing a 6 pin DCC adapter board for old (late-70s/80s) locos.
Forget most of those pins as they'll just be wires.
No bigger than the old Zero-1 modules.
Impressive delivery speed from RS Components today.
Last night I put in an order for a load of PCB sockets, diodes and spade connectors. This was done at about half eight, so I didn't expect anything to be dispatched until today. At 10:30pm I got a dispatch e-mail and today at lunchtime the stuff arrived!
The DCC decoder adapter PCBs are in Oxford now and so should be delivered on Monday.
Having got the DCC decoders themselves I can see that I could make the PCB quite a bit smaller, maybe for Mk.II if I do one.
As I had it on the bench and I had an oscilloscope handy I thought I'd investigate the voltage output from my old Hammant & Morgan Duette model railway controller, given that one of the manufacturers of a new train advised against using such old controllers.
Well, I see why now.
The unit is merely using a bridge rectifier. The nominal 12V DC is actually unfiltered full wave rectified 24V, giving an average of 12V but with 100Hz 24V sinusoidal peaks.
Testing using a 440uF cap on the tracks shows that adding a cap would flatted this out, you just can't stick an electrolytic on the line as the voltage can be reversed. So, any fix would have to take place on the inside... But the case is fully steel and pop-riveted together. *sigh*
I may drill out the pop rivets and find some small self-tappers to replace them. Then I can look inside to see if I can fit some big caps to smooth out the voltage.
stephen_usher wrote: Sat Oct 22, 2022 1:27 pm The DCC decoder adapter PCBs are in Oxford now and so should be delivered on Monday.
Nice, I should have my Aquarius composite mode PCBs on Monday too :)
stephen_usher wrote: Sun Oct 23, 2022 2:37 pm As I had it on the bench and I had an oscilloscope handy I thought I'd investigate the voltage output from my old Hammant & Morgan Duette model railway controller, given that one of the manufacturers of a new train advised against using such old controllers.
I'd be interested to see the inside of the controller if you do decide to pull it apart.
