Thanks. Apparently in 48K mode it beeps once and in 96K mode it beeps twice.
The RAM refresh issue is due to the system using the Z80's refresh which only does 128 rows and not 256, which all the TI chips need. Older 4164 allowed 4116 compatible refresh cycles.
I'm still not getting anywhere with the keyboard issue. From the hardware point of view everything looks fine. I've put some pull-ups on the keyboard read lines which has helped what they look like when a key is pressed but it made no difference. It's almost as if an I/O read isn't happening now and again. Maybe it's a timing issue?
The machine seems to be running happily in 48K mode, other than the keyboard issue. I've managed to load the game "Star Trek", which is mostly BASIC, so the tape interface definitely works.
I've ordered a 74S138 from Mouser, along with 500 decoupling caps to make it half worthwhile.
I have a feeling that the 74LS138 is marginally too slow for the keyboard read timing and the CPU is reading zeros on random lines on the bus.
Seeing as the keyboard issue is probably timing as I have some 74Sxx parts on the 128 board I thought I'd fit them where maybe they could do some good.
The two 74S04s worked in two places but caused video timing issues in another.
The 74S74 dual flip-flop caused all sorts of fun when I put it in the RAM timing circuit, only with the video RAM though. I moved it into another signal path and the machine is happy.
I also tried replacing the 74LS244s and 245s with AHCT variants, in case they would help as they switch slightly faster. The only difference it made was to the temperature. The AHCT parts run stone cold, unlike the LS ones, one of which had been running at over 40C.
After these changes the keyboard issue may be slightly less but not remarkably better.
stephen_usher wrote: Thu Sep 24, 2026 10:53 pm
That's reminding me of all the timing issues I had with my OSI 600D and modern ICs...
And I'm still getting nowhere with the keyboard issue.
I've traced every timing path, which isn't very much, which enables the keyboard read, and the other signals and the only things of note are that the output of the '138 is a bit spikey and one of the sides of a CD4538BE is never active, with it held in reset most of the time but any signal on the input data line misses that region by about 100ms. (Data input from the 6845 CURSOR pin and reset from the video latch signal. The output help generate the CPU halt signal.)
I've tried putting pull-ups on the RAx address lines going into the '138, which tidies them up, and one on the output, and on the whole the signal looks better but it's not changed anything. Changing from an LS part to an F part has made no difference.
My suspicion is that the CPU is trying to do an IN instruction and is reading the bus when it shouldn't be and getting the incorrect value.
The 74S138 arrived today... Didn't help with the keyboard issue.
Some 128 row refresh capable 4164 RAM arrived today so the machine is stable in the 96K configuration.
Just in case the keyboard issue was due to power issues I fully fitted the board out with decoupling caps... No change.
