Seeing as CL5 is on the horizon, the Camputers Lynx 128K doesn't run games and the feeling that I need to solder something I decided to try to build the Lynx 96K PCB I have to get that working.
So, I've spent the day soldering sockets, resistors, diodes, transistors and ceramic caps. Unfortunately I ran out of 470R, 1K and 4.7K resistors so I've had to put in an order with Amazon for those.
Still, good progress. A quick power test showed that I had two of the diodes the wrong way around, helped by the thermal camera. That's fixed now and no harm done.
- IMG_5405.jpeg (261.28 KiB) Viewed 31 times
Tomorrow I can fit more decoupling caps, though I don't think that I have enough to complete but should be good enough to get going. I can also fit the header pins and electrolytic caps. I can also get on with the video RAM board.
