Uh Oh.Electron inbound
Re: Uh Oh.Electron inbound
I think that I saw a thread on Stardot with someone with a similar symptom. I can't remember what the solution was though.
stephen_usher wrote: 15 Jul 2024 15:23 I think that I saw a thread on Stardot with someone with a similar symptom. I can't remember what the solution was though.
Thanks, I'll take a look.
EDIT - I found a 'No Colour' thread, but there was no conclusion. I need to have a poke around the colour encoder circuit, which is IC10, IC14, IC15 & IC16.
RGB output is perfect, so I know it's something to do with that circuit, it may also be worth trying it on UHF to see if that's also affected, though I think it will be.
OK, so it's fixed.
IC 15 was bad.
There have been a few dead IC's on this machine, I wonder if it was overvolted at some point.
Return to “8 BIT CORNER”
Users browsing this forum: CCBot and 3 guests
