Moron1260... but its at least got ground plane connected
TF1260 Firmware Update ... er Update?
- Admin sponsor
Re: TF1260 Firmware Update ... er Update?
- Admin sponsor
Just a reminder to folks not to buy second hand TF1260s.
1. You will not get firmware updates.
2. Every card has a unique software identifiable serial number. I will find ways to make your card useless with updated software.
3. Firmwares are read protected so you cannot read your mates card and flash yours.
If you sell your TF1260 you will not get another one.
This is done to stop scumbags flipping TF1260s for a profit. Seen one of those this weekend. I recommend the buyer return it to the person they bought it from and then contact supaduper for a TF1260 at normal price and be eligible for updates.
- Admin sponsor
Some tests have been done on various cards... including the TF Beta Frimware.
Bottom line. TF1260 has a faster RAM controller than you think
That is a lot of bang for the buck.
Great work!
Great work!
What's the X axis on that second bar chart? Are larger numbers better or worse?
- Admin sponsor
You'd need to ask.. unsure.stephen_usher wrote: Mon Jul 05, 2021 4:19 pm What's the X axis on that second bar chart? Are larger numbers better or worse?
When you realise firmware?terriblefire wrote: Mon Jul 05, 2021 4:05 pm Some tests have been done on various cards... including the TF Beta Frimware.
You have some plans?
- Admin sponsor
When its ready. There is the issue of 75Mhz limit to solve.
You want to do 100mhz ?
- Admin sponsor
Its unlikely to get that fast. But the answer to all questions will be "when its ready"
EDIT: This card is 1260 power for roughly 1230 money (if you put a £40 LC060 in there). I think its already "good enough" but want to do this last change for the Tf360 which seems to go nuts trying to do CD drive arb with the clock switching trick.
I'm not the sort that will spend years squeezing every last drop of performance out of it. I dont care that much.
