8 Bit Dreams wrote: 01 Jun 2021 06:10
installation of the 3.2 on CD32 breaks IDE function of TF330 card
How did they manage that? Did they remove scsi.device from the ROM... Seems like the AmigaOS developers do not understand how the CD32 works.
cd.device is what controls the CD drive.
scsi.device is what controls the IDE interface.
They are separate but they 100% refuse to listen to me on this.
@8 Bit Dreams Where did you get the CD32 rom. its not on the CD.
terriblefire wrote: 01 Jun 2021 09:59
Nope, it is still there, but seems SCSI.device is somehow screwed up,
I did OS 3.2 installation without physical ROM, so it gets updated after a soft reset just like on 3.9
Tested SCSI.device from 3.1.4 and IDE still boot fine, so yeah...
Dont think thats a good test. Need to burn the rom and see.
Be careful while doing Tests on 3.2,
KS Screen will not appear if floppy Drive is not connected,
You will get black screen only..
Advertised CD32 ROM is not included,
Thanks for the heads up 8 Bit Dreams good to know about the black screen with no floppy :-D . Will be trying it on my Cd32's too :D . Did you (anyone) happen to try it on a TF328? If it breaks the IDE on the TF330 how did you boot back into it for it to "update after soft reset"? or is that the point it wont boot back into the IDE after installing? Did you do a fresh install or did you upgrade? is upgrading even an option
terriblefire wrote: 01 Jun 2021 13:24
Dont think that's a good test. Need to burn the rom and see.
I agree, plan on burning a 3.2 ROM for my CD32 from the CD but if it's not included well, I'll see how I make out when my copy comes in.
8 Bit Dreams wrote: 01 Jun 2021 20:23
You can't atm, because Remus does not support KS 3.2
producing the extended rom isnt that hard.. its just a chain link and a checksum. you could brute force it.
well.. Alinea reported that they've built CD32 ROM an got it working,
they'll do a TF330 test before ship them out,
im not sure was current scsi.device fixed or they just replaced it with one from 3.1.4
we'll see
what about You @RetroPassionUK, will You also provide CD32 ROM?
What you mean with this? Is it so that all kickstart modules are not available as single files, that you would need to use rom split to get them? What is problem?
If modules are available you can buil kickstart with remus.
utri007 wrote: 01 Jun 2021 22:47
I'm not sure that remus (i use romtool in amitools - it doesnt) actually supports the CD32 Extended ROM. But its not hard to reimplement it.
