The Cosmic Puppet's Universe.
Cosmic Puppet
Re: The Cosmic Puppet's Universe.
Post by Cosmic Puppet »
I thought this was something technical :lol:
Screenshot 2021-10-17 190511.jpg (60.63 KiB) Viewed 3779 times
Cosmic Puppet
aex The Tangerine Dream Machine.
Hadn't thought of trying this with a full sound set before:
Post by JezC »
@Cosmic Puppet Hi Tony, Reading the EmuTOS team responses sounds liek a fix for the crash you saw with the latest EmuTOS release has now been fixed,, so if you update in a day or two with the newest nightly build it should be working as intended.
If only we had support like that for our modern software!
A big thanks to the wonderful EmuTOS team! :thumbup:
Cosmic Puppet
JezC wrote: Sun Oct 17, 2021 9:39 pm @Cosmic Puppet Hi Tony, Reading the EmuTOS team responses sounds liek a fix for the crash you saw with the latest EmuTOS release has now been fixed,, so if you update in a day or two with the newest nightly build it should be working as intended.
Thanks @JezC ! I will try it tomorrow.
I had the good sense to get a new SD card so I can test the water first. I only have to swap out the .prg file and sort the auto sort and NVDI settings (and yes I tried the release without anything added.) ;)
Yes, they've been very patient with me and I really appreciate it! :thumbup:
Cosmic Puppet
I mean in a day or two.
Cosmic Puppet
Latest EmuTOS build has altered Notator.
I hadn't noticed the message saying it was up because of the way gmail hides bits of text.
Kandinsky now works properly. Unfortunately it has broken Notator.
It looks like this:
Instead of this:
NOTATOR (normal).jpg (87.45 KiB) Viewed 3707 times
Please ignore the memory count difference. This is just because I switched off NVDI to check if the fault still occurred.
I've also noticed that the file selector has changed:
File Selector.jpg (84.04 KiB) Viewed 3707 times
Instead of this:
File Selector (Normal).jpg (80.2 KiB) Viewed 3707 times
czietz
Post by czietz »
Since I don't own Notator I need more info, please:
1. Exactly which two EmuTOS versions are you comparing for the screenshots?
2. What is "broken"? At the first glance I only notice a minor graphical glitch in the title bar (left to "Notator 3.21").
Cosmic Puppet
Hi @czietz I'm comparing the the 1.1.1 (2021-07-19) EmuTOS release with the latest snapshot.
The fourth value of the bar position and bar location points is also obscured.
Tony
Post by JezC »
Hi @Cosmic Puppet Didn't someone (Roger?) on the EnuTOS team get access to a Notator dongle before to investigate the original screen corruption you noticed with an older (v0.9) EmuTOS?
If so, would they still have access to it?
Cosmic Puppet
JezC wrote: Tue Oct 19, 2021 11:36 am Hi @Cosmic Puppet Didn't someone (Roger?) on the EnuTOS team get access to a Notator dongle before to investigate the original screen corruption you noticed with an older (v0.9) EmuTOS?
Hi @JezC Yeah, he messaged in the development through asking Christian if he would like him to look at it.
