Server downtime
Latest Atari related news.
Re: Server downtime
:excited: :stars: :chairsmack: :headbang: :crazy:
Re: Server downtime
Apologies for the down time earlier tonight. Was down between about 7pm and 9pm. I was at my girlfriend's so couldn't access the server from her PC. Basically someone forgot to renew the HTTPS certs again :roll: :chairsmack: :roll:
Re: Server downtime
exxos wrote: 23 Jan 2022 23:16 Apologies for the down time earlier tonight. Was down between about 7pm and 9pm. I was at my girlfriend's so couldn't access the server from her PC. Basically someone forgot to renew the HTTPS certs again :roll: :chairsmack: :roll:
:dizzy: :dizzy: :dizzy:
Re: Server downtime
I can find out how I've got my Linux box renewing the LetsEncrypt certificates automatically if you like.
Re: Server downtime
stephen_usher wrote: 24 Jan 2022 08:13 I can find out how I've got my Linux box renewing the LetsEncrypt certificates automatically if you like.
Yeah may help. I'm using getssl and should be possible as a cron job, but I've never got it working :( I use gzip and rsync as a cron job and that works fine :shrug:
Re: Server downtime
OK, try this...
I've removed my account details (I think) but it still has my domains.
It's using acme.sh but in a global location, which acme.sh isn't really designed to do for some stupid reason.
Re: Server downtime
I found a crontab generator so I guess this would / should work
derkom
Re: Server downtime
Post by derkom »
Be careful with things like "./scriptname" in your crontab, because that's going to try to execute a script in whatever is cwd when crond runs the task. I honestly don't even know what that will be, $HOME? /? I would suggest always using absolute paths in crontabs.
Re: Server downtime
derkom wrote: 24 Jan 2022 18:40 Be careful with things like "./scriptname" in your crontab, because that's going to try to execute a script in whatever is cwd when crond runs the task. I honestly don't even know what that will be, $HOME? /? I would suggest always using absolute paths in crontabs.
:dualthumbup:
Assume nothing, including the PATH for scripts which run as root.
derkom
Re: Server downtime
Post by derkom »
stephen_usher wrote: 24 Jan 2022 19:21 including the PATH for scripts which run as root.
Good point, especially the PATH for scripts which run as root! :lol:
Users browsing this forum: CCBot and 55 guests
