TQFP Soldering Gods Required! (PAID WORK)
dalek
Re: TQFP Soldering Gods Required! (PAID WORK)
Post by dalek »
For the ppc I don't think a dremel is a good idea - I think chipquick smd removal would be my go to.
sety
Post by sety »
dalek wrote: 08 Mar 2021 02:00 For the ppc I don't think a dremel is a good idea - I think chipquick smd removal would be my go to.
I second that. Chipquik and an electric vacuum pickup tool is by far the safest and easiest method I've found so far for removing large QFP. It's expensive stuff but it's worth it when working with rare stuff.
I find it's worth practicing on some old DVD players first. You can usually find them for free. Once you can get the video processor IC off and back on and the DVD player still works, then you're good to go.
Return to “ELECTRONICS”
Users browsing this forum: CCBot and 46 guests
