Re: REV 3 - REV 5 - The beginning (ST536)
Experimented with enabling ST RAM cache (whether or not this is a good idea or not I don't know, but I did it anyway :lol: )
Before and after.
Frontbench gives 2992 frames without cache, with cache gives 3039 frames.
@exxos @Badwolf I didn't reformat the card. I wrote a backup image on yo a new card. One from China buy a different brand. Same IDE driver, partition sizes etc, just a different CF card.
PhilC wrote: Thu Dec 04, 2025 9:01 pm @exxos @Badwolf I didn't reformat the card. I wrote a backup image on yo a new card. One from China buy a different brand. Same IDE driver, partition sizes etc, just a different CF card.
What CF card was malfunctioning exactly then ?
Can you verify the backup image you took against the bad CF card ?
coonsgm
Post by coonsgm »
I'm running a slightly different version of the Beta5 firmware, but it's working fantastic so far. YAART TT Ram test made it through 7 passes before I stopped to run Gembench here. Now just running Frontbench on loop.
coonsgm wrote: Thu Dec 04, 2025 9:45 pm I'm running a slightly different version of the Beta5 firmware, but it's working fantastic so far. YAART TT Ram test made it through 7 passes before I stopped to run Gembench here. Now just running Frontbench on loop.
:goodpost: :bravo:
I put the Alliance SDRAM firmware on the website as well, seems to need slightly slower timings than the winbond I have been using. So your scores are slightly less than expected but not a huge difference than norm :) being stable is the key thing at this point anyway :)
coonsgm
Post by coonsgm »
Working in both my newest H5 and a Mega ST.
coonsgm wrote: Thu Dec 04, 2025 9:50 pm Working in both my newest H5 and a Mega ST.
:yay: :yay: :yay: :yay:
coonsgm
Post by coonsgm »
Copied over 1gb of files from an ultrasatan connected to the ACSI to the internal IDE. No issues.
Day of the Tentacle runs great
Grind / Dread runs wonderfully
STDoom also runs just fine as well - at a playable framerate
Aha! So possibly incompatiblity with the card. That ties in with what @exxos found with one of mine.
coonsgm wrote: Fri Dec 05, 2025 2:52 am Copied over 1gb of files from an ultrasatan connected to the ACSI to the internal IDE. No issues.
Good to know. I haven't even tested a ultrasatan yet..
Nice!
I'm doing a little patch board.. Just as a tapped delay line, so I can fiddle with that clock a little bit more..
I'm tempted to put a buffer on the CPU clock as well.. its not helping matters exactly either.
