Decided to hardwire the SDRAM clock back to the master OSC again.. and its booted up fine (need to do more tests)
This was the clocks PLD driven..
BLUE = CPU clock (50MHz)
YELLOW = SDRAM CLOCK (100MHz)
- IMG_4061.JPG (281.67 KiB) Viewed 97 times
Master OSC driven..
- IMG_4062.JPG (251.07 KiB) Viewed 97 times
Not massive change.. but clear something has changed on the rise and fall... More voltage output as well.. Those changes are enough to make or break it it seems
I mean maybe the timing report wasn't lying afterall ... (max clock)
- Capture.PNG (19.82 KiB) Viewed 95 times
Now with about 250R in series with the clock...
- IMG_4063.JPG (262.98 KiB) Viewed 91 times
GB6 ran fine now as well..
So i'm leaning towards the PLD can't drive 100MHz SDRAM clock reliably now.. I mean it struggles to even hit 2v p-p a lot of the time. The min voltage on the SDRAM inputs is 2V !
Its running YAARTTT.. Will leave it on for a bit and see what happens now...
