exxos wrote: Tue Oct 28, 2025 6:21 pm
That works for my programmer...
I checked again and first ROM I burned had the correct byte order, which means that the first proto is (still) dead. Whatsoever, obviously a third party is swapping the bytes back ...
I built up the second prototype now and it partially works.
- Boot from 2.06 freezes in several states, mostly during the TT RAM test. If I get to the desktop an opened floppy directory may show folders and files with wrong icon types. Folders can be opened, but files seem to contain garbage.
- 20251029_225118.jpg (302.51 KiB) Viewed 71 times
- Boot with EmuTOS "works" all the time. IDE seems to be entirely unproblematic. Floppy and ACSI read seem to work but I didn't dare to write a lot to them so far ... As you can see, there is no Blitter on the board ...
- 20251029_224856.jpg (77.66 KiB) Viewed 71 times
Interrestingly EmuTOS seems to work a tad more stable with mainboard ROMs still in place. In that configuration I had a few boot runs, where my NOVA/MACH32 combi worked nicely. In all other cases I get garbage and strange offsets between windows and mouse position. Interestingly, if the MACH32 initializes correctly, it works like a charm with no "pixel rot" or the like. I checked two of my 030 CPUs so far and they show absolutely same behaviour in the ST536 and TF536.
In order to rule the CPU finally out, I could extract the CPU from my DFB1X and try it as well.
- 20251030_000938.jpg (140.85 KiB) Viewed 71 times
Under EmuTOS GEMbench ran through in all circumstances and the measured performance seems to be reasonabe considering that ROM is not copied into TT RAM. My current hypothesis is, that code execution is bad/flaky within the TT RAM. Probably I need to check that in more detail next or try to get rid of these IMP chips in the board, or some of them ...
This is how I hope it will look soon (Here with TF536 and agranlund's 2xEmuTOS boot solution):
- 20251026_143941.jpg (140.46 KiB) Viewed 71 times
