Re: REV 3 - The beginning
@Badwolf
slight tweak..
assign BERR = CPCS_INT & altrambuserr ? 1'bz : 1'b0;
EMUTOS says 64MB now :thumbup:
So at least that problem is figured out... Just need to figure out this odd dram corruption issue next :roll:
exxos wrote: Thu Apr 29, 2021 11:32 am @Badwolf
slight tweak..
Top. :mrgreen:
My money's on an errant bit of address decode logic. Double check the ROM and AltRAM logic, plus anything else (bar bus error which we've now sorted) that makes decisions based on the address bus.
Anything encompassing lines 23:20 for particular attention.
czietz
Post by czietz »
slight tweak..
Note that -- as already stated on the list -- it is not required to have a bus error (though it certainly helps as you found out). If EmuTOS detected more than 64 MB of Alt-RAM before, there must have been memory that was writeable and readable above the 64 MB mark. For example, some TT-RAM cards for the TT don't generate a bus error, either, and they are still correctly sized by EmuTOS.
EDIT: I just replied to your Sysinfo screenshot on the EmuTOS list: "These are the exception vectors located at the beginning of ST-RAM! This is *exactly* what I suspected: ST-RAM is mirrored at 0x5000000 and, thus, detected as additional "alt-RAM". This is without a doubt a bug in the address decoding on the TF card."
Badwolf wrote: Thu Apr 29, 2021 11:37 am My money's on an errant bit of address decode logic.
Isn't there IDE on the TF? Maybe addresses 0x1F00000 etc. are wrongly decoded to IDE...
I'm just doing a loop to output "bad" addresses..
 error     55    238   $F00000   %111100000000000000000000
 error     55    238   $F00400   %111100000000010000000000
 error     55    238   $F00800   %111100000000100000000000
 error     55    238   $F00C00   %111100000000110000000000
 error     55    238   $F01000   %111100000001000000000000
 error     55    238   $F01400   %111100000001010000000000
 error     55    238   $F01800   %111100000001100000000000
 error     55    238   $F01C00   %111100000001110000000000
 error     55    238   $F02000   %111100000010000000000000
 error     55    238   $F02400   %111100000010010000000000
 error     55    238   $F02800   %111100000010100000000000
 error     55    238   $F02C00   %111100000010110000000000
 error     55    238   $F03000   %111100000011000000000000
 error     55    238   $F03400   %111100000011010000000000
 error     55    238   $F03800   %111100000011100000000000
 error     55    238   $F03C00   %111100000011110000000000
 error     55    238   $F04000   %111100000100000000000000
 error     55    238   $F04400   %111100000100010000000000
 error     55    238   $F04800   %111100000100100000000000
 error     55    238   $F04C00   %111100000100110000000000
 error     55    238   $F05000   %111100000101000000000000
 error     55    238   $F05400   %111100000101010000000000
 error     55    238   $F05800   %111100000101100000000000
 error     55    238   $F05C00   %111100000101110000000000
 error     55    238   $F06000   %111100000110000000000000
 error     55    238   $F06400   %111100000110010000000000
 error     55    238   $F06800   %111100000110100000000000
 error     55    238   $F06C00   %111100000110110000000000
 error     55    238   $F07000   %111100000111000000000000
 error     55    238   $F07400   %111100000111010000000000
 error     55    238   $F07800   %111100000111100000000000
 error     55    238   $F07C00   %111100000111110000000000
 error     55    238   $F08000   %111100001000000000000000
 error     55    238   $F08400   %111100001000010000000000
 error     55    238   $F08800   %111100001000100000000000
 error     55    238   $F08C00   %111100001000110000000000
 error     55    238   $F09000   %111100001001000000000000
 error     55    238   $F09400   %111100001001010000000000
 error     55    238   $F09800   %111100001001100000000000
 error     55    238   $F09C00   %111100001001110000000000
 error     55    238   $F0A000   %111100001010000000000000
 error     55    238   $F0A400   %111100001010010000000000
 error     55    238   $F0A800   %111100001010100000000000
 error     55    238   $F0AC00   %111100001010110000000000
 error     55    238   $F0B000   %111100001011000000000000
 error     55    238   $F0B400   %111100001011010000000000
 error     55    238   $F0B800   %111100001011100000000000
 error     55    238   $F0BC00   %111100001011110000000000
 error     55    238   $F0C000   %111100001100000000000000
 error     55    238   $F0C400   %111100001100010000000000
 error     55    238   $F0C800   %111100001100100000000000
 error     55    238   $F0CC00   %111100001100110000000000
 error     55    238   $F0D000   %111100001101000000000000
 error     55    238   $F0D400   %111100001101010000000000
 error     55    238   $F0D800   %111100001101100000000000
 error     55    238   $F0DC00   %111100001101110000000000
 error     55    238   $F0E000   %111100001110000000000000
 error     55    238   $F0E400   %111100001110010000000000
 error     55    238   $F0E800   %111100001110100000000000
 error     55    238   $F0EC00   %111100001110110000000000
 error     55    238   $F0F000   %111100001111000000000000
 error     55    238   $F0F400   %111100001111010000000000
 error     55    238   $F0F800   %111100001111100000000000
 error     55    238   $F0FC00   %111100001111110000000000
 error     55    238   $1F00000   %1111100000000000000000000
 error     55    238   $1F00400   %1111100000000010000000000
 error     55    238   $1F00800   %1111100000000100000000000
 error     55    238   $1F00C00   %1111100000000110000000000
 error     55    238   $1F01000   %1111100000001000000000000
 error     55    238   $1F01400   %1111100000001010000000000
 error     55    238   $1F01800   %1111100000001100000000000
 error     55    238   $1F01C00   %1111100000001110000000000
 error     55    238   $1F02000   %1111100000010000000000000
 error     55    238   $1F02400   %1111100000010010000000000
 error     55    238   $1F02800   %1111100000010100000000000
 error     55    238   $1F02C00   %1111100000010110000000000
 error     55    238   $1F03000   %1111100000011000000000000
 error     55    238   $1F03400   %1111100000011010000000000
 error     55    238   $1F03800   %1111100000011100000000000
 error     55    238   $1F03C00   %1111100000011110000000000
 error     55    238   $1F04000   %1111100000100000000000000
 error     55    238   $1F04400   %1111100000100010000000000
 error     55    238   $1F04800   %1111100000100100000000000
 error     55    238   $1F04C00   %1111100000100110000000000
 error     55    238   $1F05000   %1111100000101000000000000
 error     55    238   $1F05400   %1111100000101010000000000
 error     55    238   $1F05800   %1111100000101100000000000
 error     55    238   $1F05C00   %1111100000101110000000000
 error     55    238   $1F06000   %1111100000110000000000000
 error     55    238   $1F06400   %1111100000110010000000000
 error     55    238   $1F06800   %1111100000110100000000000
 error     55    238   $1F06C00   %1111100000110110000000000
 error     55    238   $1F07000   %1111100000111000000000000
 error     55    238   $1F07400   %1111100000111010000000000
 error     55    238   $1F07800   %1111100000111100000000000
 error     55    238   $1F07C00   %1111100000111110000000000
 error     55    238   $1F08000   %1111100001000000000000000
 error     55    238   $1F08400   %1111100001000010000000000
 error     55    238   $1F08800   %1111100001000100000000000
 error     55    238   $1F08C00   %1111100001000110000000000
 error     55    238   $1F09000   %1111100001001000000000000
 error     55    238   $1F09400   %1111100001001010000000000
 error     55    238   $1F09800   %1111100001001100000000000
 error     55    238   $1F09C00   %1111100001001110000000000
 error     55    238   $1F0A000   %1111100001010000000000000
 error     55    238   $1F0A400   %1111100001010010000000000
 error     55    238   $1F0A800   %1111100001010100000000000
 error     55    238   $1F0AC00   %1111100001010110000000000
 error     55    238   $1F0B000   %1111100001011000000000000
 error     55    238   $1F0B400   %1111100001011010000000000
Will do a more in-depth run but it will take a lot longer...
czietz wrote: Thu Apr 29, 2021 11:53 am Isn't there IDE on the TF? Maybe addresses 0x1F00000 etc. are wrongly decoded to IDE...
hmmm yep.. I had a lot of trouble trying to figure out the decoding syntax, eventually I got a line to work.. (but IDE interface isn't yet finished either)
@Badwolf ??
wire ide_access  = ({A[23:16]} != {8'hF0});
Might just rip out the module just to rule it out..
czietz
Post by czietz »
exxos wrote: Thu Apr 29, 2021 12:06 pm
Well, that's of course problematic, as it matches all addresses that follow the pattern 0x??F0????, including alt-RAM addresses 0x01F00000, 0x02F00000, and others.
Well there's your problem. It doesn't take into account anything in the altram address range. Great shout, @czietz!
I suspect in the original firmware this is disregarded if altram is flagged, but perhaps not here.
Again, should be an easy enough fix:-
wire ide_access  =  A[27:16] != 12'h0F0;
How about that (just adds the next four lines up and enforces them to be 0 -- ie, below TTRAM space)?
Badwolf wrote: Thu Apr 29, 2021 12:18 pm Again, should be an easy enough fix:-
Right, so that came from the TF520.. It was the only line I could get to work to find IDE, but I think the 520 may have only had 4MB of RAM. or none.. can't remember..
Though should that be using up to A29 @Badwolf ?
I disabled the IDE..
I think I been that hellbent on thinking there is a RAM timing problem, Or some timing problem relating to ROM, I did not actually consider the IDE decoding, I had actually forgotten all about it :roll:
So thanks @czietz & @Badwolf :cheers:
exxos wrote: Thu Apr 29, 2021 12:39 pm
A29 will only come into play if you get up to 512MB RAM. A26 is technically enough, but by using A27 it's a nice three-hex-digit number.
*That said* it is decoding the whole of the x0F0xxxx range when only the first 40 bytes are technically needed, I believe, but I think this is safe and relatively low overhead logic-wise.
