PLD SDRAM controller ?
Re: PLD SDRAM controller ?
Badwolf wrote: 22 Jan 2021 11:54 Good luck. I'm guessing this is an Alt-RAM plug in for the STF? :)
Yeah, I am doing a "quick" SRAM board to get me moving (I messed up the first one :roll: ) , though with SDRAM being cheap with the xlinix being 5V tolerant, It could pretty much run on 5V or 3.3V busses.. Couple this with a 68K which can run at 64Mhz... ultimately I want to port to the 020, so the same SDRAM board should be adaptable for 32bit fast-ram.
Users browsing this forum: CCBot, Majestic-12 [Bot] and 5 guests
