Problem is the endless problems these original machines have. I just don't have the time to debug them all. The H5 is the way forward, the TF536 works fine on that.DaveC wrote: Mon Jun 28, 2021 10:27 pm I know I'd like some sort of booster, would prefer it to be for my STe as I'd like to be able to use DMA sound and MiNT. Though MINT isn't great with only 4Mb to use. Guess I could hope for the STe TF adapter?
STE 32MHz PLUG IN BOOSTER (again) 2021 variation
Re: STE 32MHz PLUG IN BOOSTER (again) 2021 variation
I know no DMA sound there unfortunately. Just waiting for my H5 board, and hoping I can get away with buying a Flashy Clock and TF536 without the missus murdering me
MegaSTEarian
Is this kit sold in the store? I couldn't spot it
https://www.exxosforum.co.uk/forum/viewt ... =24&t=4441
Also, do you think you can pre-wire parts that can be prewired? Trying to make it as solder less as possible
I've not finished building them yet.MegaSTEarian wrote: Wed Jun 30, 2021 9:28 am Is this kit sold in the store? I couldn't spot it
https://www.exxosforum.co.uk/forum/viewt ... =70#p66642
But there is a place-holder in the store.
https://www.exxosforum.co.uk/atari/store2/#0213
Its assembled as shown in the image, that's all I can do.MegaSTEarian wrote: Wed Jun 30, 2021 9:28 am Also, do you think you can pre-wire parts that can be prewired? Trying to make it as solder less as possible![]()
MegaSTEarian
exxos wrote: Wed Jun 30, 2021 9:36 amI've not finished building them yet.MegaSTEarian wrote: Wed Jun 30, 2021 9:28 am Is this kit sold in the store? I couldn't spot it
Cheers, thanks. I have the previous version and haven't yet dared to install it.
- HigashiJun
Back to business after a while...exxos wrote: Sat Feb 13, 2021 2:26 pm The booster has 2.2K on it. So no need to replace the MB sils,just take them out.
BTW do you have other STEs to try it out on ?
I tried your booster in another STE board I bought some months ago and it seems to work great.
I did not tried further as I am still making some mods on the board, but I managed to make the booster work with an IDE interface, which seems promising.
I should have some free time from now on to investigate a bit further.
Thanks for the updateHigashiJun wrote: Tue Jul 13, 2021 2:01 pm I tried your booster in another STE board I bought some months ago and it seems to work great.
- HigashiJun
And some Gembench results...
With blitter off:
and blitter on:
With blitter off:
and blitter on:
Although you're doing Blitter on vs off at Hi Res, you may want to try it in Med Res as that is what the reference results are based on so you will have a better comparison against 'standard'.
Unless of course you only have access to Hi Res, in which case ignore me
- HigashiJun
Here they are:rubber_jonnie wrote: Mon Jul 19, 2021 9:27 am Although you're doing Blitter on vs off at Hi Res, you may want to try it in Med Res as that is what the reference results are based on so you will have a better comparison against 'standard'.
Unless of course you only have access to Hi Res, in which case ignore me![]()
blitter off:
and blitter on:
Cheers.
