TRUDIE V5.2 (5 volt) pre-release install guide
IDE, ACSI etc kits and products.
Re: TRUDIE V5.2 (5 volt) pre-release install guide
Post by JezC »
@exxos Probably in a week or so...need payday to arrive first!
Would be great if you can add that to the next order...but I can wait longer if necessary.
Almost finished soldering up a minimal H5C1 build... :roll:
alienkidmj12
Post by alienkidmj12 »
where is jp13 on the h5 c1? it's not where it says it is on the image, or is that for h4?
alienkidmj12 wrote: Wed Aug 11, 2021 8:14 am where is jp13 on the h5 c1 ? its not where it says it is on the image, or is that for h4 ?
The image shows where the green wire goes ..
https://www.exxosforum.co.uk/forum/viewt ... 730#p54885
alienkidmj12
i see it, it's not there is actually a bit higher up,
Sorry if I missed it, but do I need to hook up IRQ for Trudie to work on a stock ST?
Steve wrote: Sat Aug 21, 2021 9:18 pm Sorry if I missed it, but do I need to hook up IRQ for Trudie to work on a stock ST?
IRQ is still needed on all machines.
exxos wrote: Sat Aug 21, 2021 11:32 pm IRQ is still needed on all machines.
@Steve the pic below shows the easiest way to hook it up on an H4/5
And on a stock ST? Where would I find IRQ? Thx
Steve wrote: Sun Aug 22, 2021 11:27 am And on a stock ST? Where would I find IRQ? Thx
Pick it up from the inside of the ACSI socket perhaps Steve?
DoG
Post by DoG »
Pin 10 on ACSI connector.
EDIT: It goes to a 74LS04 on the board.
Return to “HARD DRIVES”
