exxos IDE interface (untested)
Re: exxos IDE interface (untested)
Look nice :bravo: :coolpics:
Mine is taking shape...
Nice board. I see you went for the camouflaged green LED :D
Yes, random choice out of my draw.. However it does not flash for some reason.. And the LED on the CF adapter does not flash either :shrug:
Copying files to the drive and loading from the drive seems to work fine so far though.
The original LED I took from one of my draws did not light up it was duff. Am now sporting a nice white LED. See video of it in all its flashy glory :)exxos wrote: 25 Feb 2019 12:20Yes, random choice out of my draw.. However it does not flash for some reason.. And the LED on the CF adapter does not flash either :shrug:
I tried a different adapter, and now both LEDs flash...
I think there are just so many variations of these adapters that some of them are a bit rubbish..
Just doing bit of de-fraggling :) getting rid of those pesky fraggles.
A successful test then?
Yep..Been testing it all day..
Users browsing this forum: CCBot and 3 guests
