32MHz for STEs without CPU socket
IngoQ
Re: 32MHz for STEs without CPU socket
Post by IngoQ »
Preliminary Conclusion
Obviously I like the STFM 1.5 Booster variant better, simply because of its form factor. So I guess I will stick with it, after I tested the hell out of both boosters ;)
So is this the ultimate solution for any ST?
No of course not. Not even for any STE. If your STE has a socket, you should stick with the STE booster, since it is easier to integrate.
And if your STE has no socket: Then you CAN consider the STFM 1.5 booster as well, if you are comfortable doing the same modifications as I described above. There are some ideas for a plug in solution, for those who can't or don't want to solder that much, but nothing is available at the time of this post. And let's be honest: This might only affect a couple of STEs out there. But if you - like me - are one of them, then this above is probably your only way.
Ingo :geek:
troed
Post by troed »
Fascinating reading, thanks for taking the time to document all this, including with pictures :)
/Troed
Sausageinabun
Post by Sausageinabun »
Damned fine work my friend, well done!! :)
A train station is where the train stops. A bus station is where the bus stops. On my desk, I have a work station...
:goodpost:
Deserves a hack award of the day that one does! 8-)
https://www.exxosforum.co.uk/atari/ All my hardware guides - mods - games - STOS
https://www.exxosforum.co.uk/atari/store2/ - All my hardware mods for sale - Please help support by making a purchase.
viewtopic.php?f=17&t=1585 Have you done the Mandatory Fixes ?
Just because a lot of people agree on something, doesn't make it a fact. ~exxos ~
People should find solutions to problems, not find problems with solutions.
IngoQ
Post by IngoQ »
Thank you all :cheers:
Ingo :geek:
Maeke
Post by Maeke »
The testing photo of the 1.5 is the same as the one with the ste booster.
This said, great work.
If i take too long to reply, sorry my cat is sleeping on my laps.
IngoQ
Post by IngoQ »
Maeke wrote: Wed Nov 15, 2017 12:21 pm The testing photo of the 1.5 is the same as the one with the ste booster.
Yep, you're right, corrected it :)
Ingo :geek:
IngoQ
Post by IngoQ »
Update: 8MHz Clock
Okay, apparently I was blind :) When looking at some of the pictures I had made, I discovered this:
So, YES, there is second trace at that CPU pin, but you can only see the connection, as long as there is no socket. I followed the trace, and it indeed goes more or less directly to Pin 3 at the GST/MCU/Blitter Combo, as it should:
This means, that I did not have to bend up pins like I did, I could have cut the trace and find to spots to solder on wires. I looked a little around, and found these vias to be nice spots:
I am not sure, whether I will actually do this, but this might be handy for the next one trying this :)
Ingo :geek:
Track cutting is more tricky.. more chance of slipping with the knife and damaging more tracks.. PLus some people likely cut the wrong tracks and end in a mess trying to repair them :roll:
Think you did a better job than my hack up of it all last year..
IngoQ
Post by IngoQ »
Yep, my cutted trace looks the same ;) But I was recently told, that you could use a small (5mm) drill to cut the trace. If you need to repair it, it can be done by just using a bit solder. But I have to admit, I did not yet try that.
Ingo :geek:
