DoG's H5 B1 Build
Re: DoG's H5 B1 Build
The avalanche has started. It's too late for the pebbles to vote. (Or in this case, birdseed.)
Almost all is done. I have to program a 27C4096 and get some connectors for power. I have to double check some jumpers. I have some PLCC MC68000 on order but I can boot it with the DIP 68k for now. It took longer to find all the parts then actual soldering it. Oh, need a battery later on as well.
Looking good @DoG. You need a label printer
Is that a 3D printed reset switch cap @DoG?
I looks really good in black.
Looks pretty good @DoG .
Nope. I bought reset switch and cap from RS Components. But 3D printed would probably be cheaper.
Wow! That was quickly done
Mine is still just the bare board..
So... It's been awhile since I built it. Well, it never started the first time I booted it. Black screen. No signal to monitor. Gotek screen shined though. Reset did nothing but seemed working when measured. I didn't have the time to fix it then. I had a a couple of ocular inspection on it from time to time. But I couldn't find anything obvious faulty with it.
It turned out that nothing was actually wrong with the board.
The recapped PSU I have been using (for over 1,5 years) put out 5.5V and that is not fine for the H5. Well I have used that PSU for a C070859 yesterday and that worked fine. I got it started with a MeanWell PSU I have been using for my Mega and the H5 sprung to life. So a multimeter hooked up to the connector and then screwed down to around 5V made it worked like it should. I'm so glad I didn't start doing a lot of other stuff on the board to get it working.
Odd.. But yeah 5.5V is a bit high anyway. Is your 70859 board using 2.2K bus resistors or the original ones ?DoG wrote: Thu Jan 14, 2021 3:10 pm The recapped PSU I have been using (for over 1,5 years) put out 5.5V and that is not fine for the H5.
