Sporniket's log on hardware stuff
sporniket
Re: Sporniket's log on hardware stuff
Post by sporniket »
This week I could capture the schematics around the MFP. I planned to put the serial port too, but this one is not just wiring to IO ports, there are specialized ICs and voltage regulation curcuitery. I also had to fix the previous subsheet, with a forgotten capacitor and the parallel port and wiring incorrectly labelled with "serial" everywhere ! :oops:
As usual, the git repository is up to date.
subsheet_202-U202 — PSG and Parallel IO.pdf
(54.46 KiB) Downloaded 166 times
subsheet_203-U203 — MFP 68901.pdf
(50.64 KiB) Downloaded 162 times
sporniket
Post by sporniket »
The RS-232 port and alternate voltage generation. The "-12V" is just a hunch given that it is for the RS-232 driver. In other words, "I have no idea what I'm doing".
subsheet_204-J204 — RS-232 IO.pdf
(47.72 KiB) Downloaded 161 times
subsheet_205-U204 U205 — G12V -12V -5V.pdf
(39.58 KiB) Downloaded 161 times
Anyway, the sheet #2 is done, next sheet is the DMA circuitry (DMA, WD1772 and ports).
As usual, the github repository is up to date.
sporniket
Post by sporniket »
Here is the converted schematics for the DMA IC. The original schematics is done with the DIP-40 version of chip, and my STE has the PLCC44 version. Thus, I looked at other schematics (the Mega STE and the STBooks) to also get the pinout of the plcc version. The schematics of the STBooks seems more complete to me, as the pin 30 is annotated as "TESTIN" and wired to ground, instead of being omitted in the schematics of the Mega STE.
Another thing, on my motherboard, I fail to find a second bypass capacitor, as the plcc version has 2 Vcc pins.
subsheet_300-U300 — DMA.pdf
(54.53 KiB) Downloaded 154 times
The git repository is up to date.
sporniket
Post by sporniket »
Next subsheet, the ACSI Port, and the associated buffer/line drivers ICs.
subsheet_301-J301 — ACSI Port.pdf
(52.35 KiB) Downloaded 155 times
Also, this week I received the 4Mb SIMMs for STE made by @exxos to upgrade from 512Kb RAM.
I had to push harder than expected to fully engage the SIMMs in the connector. Simply place and push is not enough.
Anyway, it was a success
Now that my STE has more than 512Kb RAM, I can finally run Gembench. (And yaart tested successfully too)
sporniket
Post by sporniket »
The FDD controller and ports. The subsheet is quite full. I also took time to finally put a licence note on the page layout descriptor.
subsheet_302.sch
(26.8 KiB) Downloaded 147 times
sporniket
Post by sporniket »
The generation of SCLK and CLK2 was quick to do, and that's the end of the sheet #3. Next sheet deals with the GSTMCU, the shifter, and the video circuitry, it won't be so quick to capture...
subsheet_303.sch
(3.82 KiB) Downloaded 151 times
sporniket
Post by sporniket »
I have just finished the GSTMCU. It fits the A4 page !!
subsheet_400.sch
(26.92 KiB) Downloaded 148 times
The github repository is up to date.
sporniket
Post by sporniket »
Hum, how embarassing. It seems that recently, I have attached the kicad subsheets instead of the pdf tracing... :oops:
subsheet_302-U301 — WD1772 and port.pdf
(111.08 KiB) Downloaded 156 times
subsheet_303-U303 — SCLK & CLK2 clocks.pdf
(50.36 KiB) Downloaded 147 times
subsheet_400-U400 — GSTMCU.pdf
(117.56 KiB) Downloaded 155 times
subsheet_401-U401 — GST Shifter.pdf
(84.22 KiB) Downloaded 152 times
sporniket
Post by sporniket »
Today I completed the Video Port. The github repository is up to date.
subsheet_402-J400 — Video Port.pdf
(92.35 KiB) Downloaded 179 times
