Check if your IP is banned
viewtopic.php?t=7286
Progress on our FPGA cores.
Icky wrote: Mon Mar 11, 2019 1:49 pm
rubber_jonnie wrote: Mon Mar 11, 2019 1:07 pm Mine has just arrived, so hoping to fire it up this week/weekend :)
Once you go HDMI/DVI you will never go back :)
I expect you are 100% right :)
Smonson
Post by Smonson »
Icky wrote: Mon Mar 11, 2019 1:49 pm Once you go HDMI/DVI you will never go back
...unless you want to run the {Closure} demo
Smonson wrote: Mon Mar 11, 2019 11:39 pm
Oh, thought it worked ?
Smonson
Post by Smonson »
Unfortunately it doesn't yet work with sync-scrolling effects. I haven't worked on it yet because my 68000 programming skills aren't up to the task of making a test-case.
Test case for what exactly ?
Smonson
Post by Smonson »
I mean a minimally-small program that can generate scanlines shifted by each of the possible amounts. Then I can experiment with code changes and see the result. With a demo, the screen is constantly moving, so you can't keep track of what's going on - and the shifter's so busy that you can't be sure what state it's in at the beginning of each frame and line.
I (or anyone, actually) can also turn that into a Verilog simulation for the publicly-available shifter code.
Somewhere troed did a program to detect current wait states. The desktop would be shifted, though I think it was ws2,ws4 which mostly came up.. After powering off for a few moments and powering back up again.. So maybe that would help ?
Smonson
Post by Smonson »
Very possibly!
Smonson wrote: Tue Mar 12, 2019 4:10 amVery possibly!
Think this is it..
https://github.com/troed/WSDETECT
I'm sure troed sent me a PRG at some point, just trying to find it, but not having much luck.
My adapter is hooked up, and boy is it sweet :)
Here's the adapter itself, hooked up in place to my NEC Multisync LCD 1970NX via a DVI cable. The DVI board had jumper B set.
Incidentally I swapped to Hi Res using a VGA adapter that was still plugged in, but not connected, and simply flicked the switch!
Here at Lo Res:
Medium Res:
High Res:
I can't begin to tell you just how sharp the picture is, the clarity is superb, this adaptor truly brings the STFM video output into the 21st century!!
Once my DVI to HDMI adapter arrives, I'll post some pictures of hookups to my TV.
Great job!
Return to “FPGA DEVELOPMENT”
