Progress on our FPGA cores.
My SR98 is outputting 5.05V, so be about the same as my "exxos psu"...
I will try running the ST + FPGA board on other voltages when I get home from work tomorrow.
exxos wrote: Wed Dec 05, 2018 11:18 pm My SR98 is outputting 5.05V, so be about the same as my "exxos psu"...
Thought I would give this a go too.
So I started at 4.3V and although my floppy failed to work the board dropped to the desktop and has been sat there stable. No resets.
Of course I can’t load anything as the floppy is not recognised at that voltage.
Will start to up the voltage to see when resetting starts
Smonson
Post by Smonson »
Icky wrote: Wed Dec 05, 2018 11:29 pm Thought I would give this a go too.
Now that is interesting.
Icky, did you try a 4700uF across the shifter power rails ?
Smonson wrote: Wed Dec 05, 2018 11:32 pm
4.4V and I started getting resets not as many as I normally get.
Have gone back down to 4.3V managed to get my Gigafile working with it and am currently running GEMBench and it’s gone through one loop without resetting.
exxos wrote: Wed Dec 05, 2018 11:35 pm Icky, did you try a 4700uF across the shifter power rails ?
Currently have a 1000uF across the rails.
So any voltage for me above 4.3V up to 5V and the board resets. I didn’t go any higher.
Icky wrote: Wed Dec 05, 2018 11:37 pm
Staring to sound like ringing or noise on a signal somewhere. Or indeed gnd bound across the FPGA board s even,
Smonson
Post by Smonson »
This gives me hope that I might be able to reproduce the issue here, by using a different power supply. Excellent!
Would be interesting to see how troed’s behaves at different voltages. See if he can replicate the same behaviour I am experiencing.
Still at 4.3V and on 5th loop now in GEMBench and no resets.
Return to “FPGA DEVELOPMENT”
