Sorry, forgot about that...
http://smonson.com/unmanaged/atari/shifter-test.hfe
http://smonson.com/unmanaged/atari/shifter-test.st
Smonson
Program doesn't seem to be doing anything ?
Tried in medium res..
now just stuck on this...
Smonson
Doing nothing is good, it means it's only reading zeroes (or 1 in medium). Like me, your machine works with the mod for some unknown reason.
I removed the cap I added and this is what happens to the video...
( still get nothing in that program with the cap removed)
Video is fine with the cap.
Smonson wrote: 30 Nov 2018 08:27 My observations:
- The latching behaviour is only level-sensitive, so high-frequency noise around the transitions shouldn't cause glitches
- The values that are being read seem very non-random, in the sense that either reads the whole word perfectly, or else it reads it with 8-12 wrong bits. It never reads just one wrong bit here and there. The pattern of bits is also very uniform, e.g. 0xb479 comes up a lot (see video and screenshot posted by Icky above)
- The reason I don't think it's clock related is that both Icky and Troed have the same behaviour, and Troed is using a totally different clock.
Could you get your program to output in binary instead ? Then be easier for people to see if any particular bit(s) are having issues...
Smonson
That's more good evidence that the register read problem isn't related to clock stability :dualthumbup:
The line of Xs is the value in binary.
Smonson
^ This is what it looks like on Icky's machine while running the test program.
Each line represents a read off the resolution register (the whole 16bit word) that differs from the previous value.
So what motherboard revisions are people using then ?Smonson wrote: 30 Nov 2018 11:44 ^ This is what it looks like on Icky's machine while running the test program.
This is mine..
Different boards tend to have different "faults".
Is everyone's HDMI board exactly like the one I have ?
Smonson
Mine's a C103414-001 rev 1.1.
The HDMI boards are all the same, unless I'm misremembering (V4).
Users browsing this forum: CCBot and 3 guests
