Progress on our FPGA cores.
Smonson wrote: Sat Sep 01, 2018 8:52 am I can't guarantee that the buffer will be fast enough for the 32MHz clock though, I recommend checking it on a scope before depending on it.
OK, what chip did you use ?
Smonson
Post by Smonson »
exxos wrote: Sat Sep 01, 2018 10:34 am OK, what chip did you use ?
74LVC245A
https://assets.nexperia.com/documents/d ... CH245A.pdf
poobah
Post by poobah »
Smonson wrote: Sat Sep 01, 2018 10:52 am
74LVC245A
Have you guys looked at the IDT QuickSwitch devices?
poobah wrote: Sun Sep 02, 2018 3:41 pm Have you guys looked at the IDT QuickSwitch devices?
I'm using them :)
troed
Post by troed »
74LVC245A
Seems plenty fast according to that spec sheet, unless I'm misunderstanding something.
troed wrote: Sun Sep 02, 2018 4:37 pm Seems plenty fast according to that spec sheet, unless I'm misunderstanding something.
I think it was just a suggestion..Nothing wrong with those of course.
For my stuff, I am pushing every MHz out of everything, so the IDT switches have pretty much zero delay, which is what I need. In case of the FPGA stuff, a few ns isn't going to make any odds. Though I guess the IDT stuff may be easier to solder as they (IIRC) are larger packages.
poobah
Post by poobah »
exxos wrote: Sun Sep 02, 2018 4:57 pm ... Though I guess the IDT stuff may be easier to solder as they (IIRC) are larger packages.
Yup, I solder them by hand fairly easily.
Smonson
Post by Smonson »
The only reason I mention the buffer is that the one I used for the 16MHz line (M74VHC1GT125DF2G) can't hack it at 32MHz. Since 16MHz is not too fast by today's standards I didn't worry about it when selecting buffers.
rpineau
Post by rpineau »
May I suggest the NB3N551 for clock buffering :
https://www.mouser.com/datasheet/2/308/ ... -83648.pdf
Smonson
Post by Smonson »
Suggestions are welcome. But from the datasheet it looks like this device is only guaranteeing to produce a 2.4v high. Dunno if the Atari would be too happy with that.
But this is definitely the kind of thing I should have used in the first place
Return to “FPGA DEVELOPMENT”
