NEC MultiSync EA190M
All information relating to connecting your ST to a modern TV/monitor.
Re: NEC MultiSync EA190M
@thesofa @exxos
The monitor manuals rarely ever say 15khz, check out the 15khz monitor wiki: http://15khz.wikidot.com/
It lists the 190M as 'partial' support which looks about right.
If I remember rightly, not all monitors are created equally despite the same model number.
I think the trick would just be to find a older TV / monitor which has VGA input.
thesofa
Post by thesofa »
exxos wrote: 28 Oct 2021 12:47 If I remember rightly, not all monitors are created equally despite the same model number.
I think I have found one here
https://www.ebay.co.uk/itm/224514845624 ... SwLqJg2vEX
Just ordered it
TT030 with Storm with 256 Mb Ram, Thunder with a CF drive and Lightning, HxC floppy emulator and one of Codekiller's magical Mono/Colour switchers, also 3 STS one has TOS1.0 AND 2.06 switchable with an HD drive, the other two are untested as yet, just bought for spares!!
Post by JezC »
@thesofa Nice find! It will be good to hear how you find it to be with your setup.
I've watched the listing in case they are worth buying in the near future.... ;)
thesofa
Post by thesofa »
@JezC It will be about a week before it gets here
Joining in with this necrothread...
I have a 1970NXp. Same interface, same scaling effects in low res evident in Exxos' screenshots.
Seems to go OK for occasional 15kHz use, but I wouldn't really recommend it unless it fell in your lap dirt cheap. Doesn't seem to like interlaced modes.
The manual also states it's a 31kHz minimum. I'd guess all these NEC multisyncs are basically the same chipset and will likely all behave the same way.
Cheers,
BW.
thesofa
Post by thesofa »
How does £36.79 sound incl delivery?
thesofa
Post by thesofa »
thesofa wrote: 28 Oct 2021 13:23
Just ordered it
It has arrived and is now finally set up after waiting 2 months for ST2VGA from Centurion, I have tested it both on My TT and on the STE and it works fine in all resolutions on both machines and it was £36.79 incl delivery
Return to “DISPLAYS & CONVERTERS”
Users browsing this forum: CCBot and 5 guests
