Atarian Computing wrote: Thu Mar 25, 2021 1:12 pm
Any way you can check what resolution it outputs in Mono and others as well?
Kinda thought you would ask that.
It reads the EDID off the connected monitor, and outputs preferentially in that mode, so if you can get your panel to advertise itself as 1280x800, you *should* be able to get the RGB2HDMI to output that mode with no fuss. But you can also force the output on the RGB2HDMI to a variety of options, and 1280x800 is on the list.
Outputting 1280x800 to my Dell 1600x1200 monitor produces an image the Dell is happy with, but of course it's not a happy integer multiple here. A big caveat though: I'm getting some odd vertical white stripes when running in mono mode...
- IMG_20210325_153207.jpg (166.06 KiB) Viewed 5519 times
I don't know if this is a problem with my hookup or with the RGB2HDMI. Will require some investigation.
Another caveat... As with other approaches to this problem, I've got the problem that the RGB2HDMI is outputting borders, which of course negates the whole value of having the 1280x800 screen. I've poked around in the menus a little bit, but haven't yet found a way to eliminate those borders. Doesn't mean it doesn't exist, as there are numerous expert level settings I haven't poked at yet.
Edit: I find that in the settings menu, there's a Debug mode that turns on vertical lines for alignment aids, and curiously they're in precisely the same locations as my errant vertical lines, although in a different colour. But my lines are
not the debug lines.
