UbiSoft MV16
Re: UbiSoft MV16
Nice idea
weav
Re: UbiSoft MV16
Post by weav »
I've got one of these carts somewhere in my endless stash.. Question I have is what other programs used this cart other than BAT/BAT2? Please say trackers/mod players!
weav
Oldskool
Re: UbiSoft MV16
Post by Oldskool »
Trackers and mod players.
According to Atari Forum:
https://www.atari-forum.com/viewtopic.php?t=9824
B.A.T.
B.A.T. II
Music Master
Some MOD-Players
Audio Sculpture
Digi Composer
TCB tracker
Noisetracker 1.5
It should be the same, as Protracker ST saysy 'ST Replay', but MV16 workst with that setting.
GadgetUK164
Re: UbiSoft MV16
Post by GadgetUK164 »
Main thing I am hoping to use it with is the new ScummST port!
Oldskool
Re: UbiSoft MV16
Post by Oldskool »
If the replay routine of both devices is the same as stated in atari forum a St replay cartridge will also work if you have one of those.
I think I have one somewhere but I can’t try it yet.
weav
Re: UbiSoft MV16
Post by weav »
Excellent! Now I just gotta find it!! :P
weav
Re: UbiSoft MV16
Post by weav »
Finally found the source for Griff's player on Maggie 8 that plays via the MV16. Wrote a silly/sad player long time ago that used an older version of his playrout. Below is the source and the compiled prg so you can test.. still gotta find the damn cart!
Griff Player Source.zip
weav
DoG
Re: UbiSoft MV16
Post by DoG »
Tried a few trackers on my Atari H4 board.
Ran Digi Composer and Noise Tracker 2 with MV16 output and it worked fine. ST Replay output also worked but was a bit lower in volume. Don't know why.
Tried Audio Sculpture v1.5 beta but it wouldn't load. Complained about to low memory but I got 4Mb. Tried it on a TT and it complained on that system also. So couldn't run that program.
Tried TCB Tracker v2.0s but I have no idea how to change output in that program so...
Re: UbiSoft MV16
weav wrote: 06 Jul 2020 01:49 Finally found the source for Griff's player on Maggie 8 that plays via the MV16. Wrote a silly/sad player long time ago that used an older version of his playrout. Below is the source and the compiled prg so you can test.. still gotta find the damn cart!
weav
@weav Can I suggest uploading the files you've mentioned to the forum, as it prevents posts from breaking if for some reason the site goes down or the link changes :)
weav
Re: UbiSoft MV16
Post by weav »
Edited to attach the file in the post. Still on probation so have to wait for it to be approved by admins.
Users browsing this forum: CCBot and 7 guests
