The difference is that the ide buffers on the rev 2 weren't wired properly but this was changed in the rev2b.
Ready built ST536 Atari version. Any Interest?
Re: Ready built TF536 Atari version. Any Interest?
derkom
I can wait. I've got too much going on to even have much time for the projects I'm actively working on. ;)
@derkom know the feeling. Will PM you.
First two boards have been sold, thank you very much to the buyers. I have a third on test right now as well.
8 Bit Dreams
- Moderator Team
May i ask what FW did U used for ST builds?
the firmware Terriblefire posted a couple of weeks ago, specifically for the ST.
sqward
I'd be interested. Already have 030 on my PAK030 which, frankly I'd be more then happy to swap for this :) Regards
Why do you want to swap the pak? I presume its a pak68/3 then?sqward wrote: 03 Jul 2020 17:10 I'd be interested. Already have 030 on my PAK030 which, frankly I'd be more then happy to swap for this :) Regards
EzdineG
Phil, do you have a list of workarounds / no-go's for those interested in these? IE which ST revisions these will fit in, which will require relocators? Will 192k EmuTOS work here for STFM machines that have that limitation?
I can help compile some of this if it isn't currently known.
Thanks!
[edit] I see you've started a new thread for that here:
https://www.exxosforum.co.uk/forum/viewt ... 156#p43156
Thanks!
sqward
Yes, I'd be happy to. I have a Pak68/3 + Frak + a buffer board and the ISA slots. But all this doesn't fit in my MegaST case so I'd rather have something more compact.
Users browsing this forum: CCBot and 11 guests
