kodak80 blog
LarryL
Re: kodak80 blog
Post by LarryL »
Hi @kodak80
I let some of your ISA PCB v1.3 be made in China for my ATX Board.
I am struggling a bit with sourcing the SMD battery holder for the RTC
Do you evtl have a source or a vendor/ part number for a suitable component?
All I could find locally here in Germany are much wider than the 20mm on the board
I assume, that the battery is a CR2032, or do you use something else?
Another question: the two holes on both sides of the cartridge connector are for a bracket, right?
I could not find a suitable bracket with latches with distance of approx 76mm - at least not for keystone brackets
Any other special bracket, you used for the design?
Cheers
Michael
kodak80
Re: kodak80 blog
Post by kodak80 »
LarryL wrote: Fri Jan 13, 2023 5:26 pm Hi @kodak80
Cheers
Michael
The battery holder is for a CR1220 coin battery. Similar to these ones:https://www.ebay.de/itm/201945271987
The bracket holes were just a convenient location so there is no standard bracket to my knowledge. I could not find any information on standard ISA keystone brackets. Someone will need to 3D design and print a bracket to fit the adapter. If there are standard brackets then I can maybe update the design to move the mounting holes.
LarryL
Re: kodak80 blog
Post by LarryL »
kodak80 wrote: Sat Jan 14, 2023 3:00 am The battery holder is for a CR1220 coin battery. Similar to these ones:https://www.ebay.de/itm/201945271987
Thanks, found the battery holder
You are right with the bracket - there is no standard one with a suitable opening
Idea was to drill and file one in a existing „closed“ bracket like the Keystone 9203
https://www.mouser.de/ProductDetail/Ke ... azwQ%3D%3D
But maybe it is easier to 3D print something
kodak80
Re: kodak80 blog
Post by kodak80 »
So, I was wondering about using Bluetooth for outputting audio from an ST. So, I created an adapter for the YM2149 chip which split the 3 analogue audio channels into stereo and then fed this into a Bluetooth emitter...
YM2149 Bluetooth adapter.jpg (327.55 KiB) Viewed 2244 times
An hey presto, I now have the audio outputting on various Bluetooth enabled audio devices.
Re: kodak80 blog
:bravo:
HigashiJun
Re: kodak80 blog
Post by HigashiJun »
Cool !
ijor
Re: kodak80 blog
Post by ijor »
Cool indeed! :)
http://pasti.fxatari.com
DoG
Re: kodak80 blog
Post by DoG »
Yay! Tower :D But very nice indeed.
kodak80
Re: kodak80 blog
Post by kodak80 »
It works...
I have an original Mastersound II Cartridge and worked with an old schematic I found on gossuin.be
It is the same size as the original.
Re: kodak80 blog
Oh wow. Beat me to it . :D
I thought it had more bits inside it.. but I've not opened it for like 30+ years..
