kodak80 blog
Re: kodak80 blog
kodak80 wrote: Fri Nov 11, 2022 1:29 pm As shared on other forums. My ISA Cartridge adapter works fine with bodge wires from underneath the GLUE IC (pins 17 & 18) for ROM3 & ROM4.
Looks good!
What address lines are exposed on the ISA slot? No chance of doign the ROM3/4 decode yourself?
Cheers,
kodak80
Re: kodak80 blog
Post by kodak80 »
Badwolf wrote: Fri Nov 11, 2022 1:53 pm
Looks good!
What address lines are exposed on the ISA slot? No chance of doing the ROM3/4 decode yourself?
Cheers,
The required address lines for the decode are not on the ISA slot. They are on the GAL IC that is used for the STGA1040 logic.
Here is the ISA slot schematic:
ISA pinout.png (271.54 KiB) Viewed 2957 times
I believe this is the decode required for ROM3/ROM4:
/ROM3 := /AS & A23 & A22 & A21 & A20 & A19 & /A18 & A17 &  A16 & RW
/ROM4 := /AS & A23 & A22 & A21 & A20 & A19 & /A18 & A17 & /A16 & RW;
Re: kodak80 blog
kodak80 wrote: Fri Nov 11, 2022 9:22 pm The required address lines for the decode are not on the ISA slot. They are on the GAL IC that is used for the STGA1040 logic.
Yeah, that looks right.
What a shame! All those pins and it stops at A18.
kodak80
Re: kodak80 blog
Post by kodak80 »
I tested the v1.1 of my ISA cart adapter yesterday and it works which is great considering I had to move from Eagle to KiCad for v1.1 due to the size of the PCB. It was too big when I moved the cartridge port outside the ATX casing and Eagle (free version) would not allow the size board needed.
I have spent time today working on the next version (v1.2) of the ISA cartridge adapter and have added in:
  • a 40 pin internal header to allow an EtherNEC adapter to be connected using a 40 pin IDC ribbon cable
  • Forget-Me-Clock II components to allow a real-time clock
Cart Adapter RTC 40 pin Header-front.png (323.61 KiB) Viewed 2907 times
Whilst I was working on this, I also deciphered the EtherNEC adapter information to create the 8-bit ISA board to connect up to the above new cartridge 40 pin header which should allow network connectivity to the mATX Atari ST.
And I have also created a fix adapter for the ACSI header that should work
ATX ACSI 20 pin Header Fix-top.png (44.07 KiB) Viewed 2907 times
ATX ACSI 20 pin Header Fix-bottom.png (37.24 KiB) Viewed 2907 times
I have placed an order for these PCBs and will get them tested once they arrive.
HigashiJun
Re: kodak80 blog
Post by HigashiJun »
Looks good !
kodak80
Re: kodak80 blog
Post by kodak80 »
Version 1.2 is now tested and RTC, cartridge port and internal 40 pin header work. EtherNEC is now also tested and works when connected to the cartridge adapter internal header.
EtherNEC testing (1).jpg (79.73 KiB) Viewed 2848 times
EtherNEC testing (2).jpg (91.87 KiB) Viewed 2848 times
EtherNEC testing (3).jpg (102.08 KiB) Viewed 2848 times
EtherNEC testing (4).jpg (75.79 KiB) Viewed 2848 times
EtherNEC testing (5).jpg (35.18 KiB) Viewed 2848 times
EtherNEC testing (6).jpg (41.35 KiB) Viewed 2848 times
Gerbers for the Cartridge Adapter and EtherNEC boards are now available on the mATX page on my website:
https://chillichai.com/atari-st-micro-atx/
Re: kodak80 blog
Thanks for sharing @kodak80
DoG
Re: kodak80 blog
Post by DoG »
Nice. Thx.
I found some DIY NE2000 card on github, based on the Realtek chip, that I will try and build. Hopefully compatible with the EtherNEC and cheaper then the NE2000 on eBay. I found both 8-bit and 16-bit ISA card. I guess the 8-bit will be enough since it is only a 8-bit ISA Socket used on the EtherNEC adapter?
kodak80
Re: kodak80 blog
Post by kodak80 »
Yes, 8 bit ISA slot is what is in the EtherNEC adapter.
I have built up 3 x 8 bit network cards from this one: https://github.com/skiselev/isa8_eth
I need to find a way to program the 93C46 - 1 Kbit EEPROM as the network cards do not seem to work without the chip being programmed. A program is provided to do this but I don't have a working PC with an ISA slot at the moment.
DoG
Re: kodak80 blog
Post by DoG »
Exactly the one I was thinking of. :D
