Check if your IP is banned
viewtopic.php?t=7286
Unable to get IDE to work on Atari
Other boosters or variants.
Re: Unable to get IDE to work on Atari
OK.I've managed to make a cable! Yay!
One of my CF cards works too.
Well, 4MB is a tad small so I'd like to use a larger one.
However... the 128MB FujiFilm CF card gives:
I can't boot with the CF drive installed (repeated crash or EmuTOS drops to the desktop and can't read any device). If I leave the system in HDDriver HDDUtil as above the system will crash after a while.
(Just forget the Hitachi 1GB Microdrive as that just locks the IDE bus.)
Any ideas as to how to get the 128MB CF card to work or is it a lost cause?
Oh. This is interesting. I connected a real 60GB hard disk and I'm getting higher bits being set in the device ID when it's read and it's not always consistant.
The drive's ID should be "IC25N060ATMR04-0" but I'm getting either "iC:5060aTMR44-0" or "iC:5060qTMR44-0" or "iC:5060qTMR<4-0". It's also reporting an erroneous size, and the corruption is getting worse the longer the machine has been running for.
This TF536 has the buffers installed.
derkom
Post by derkom »
stephen_usher wrote: Tue Mar 16, 2021 7:57 pm The drive's ID should be "IC25N060ATMR04-0" but I'm getting either "iC:5060aTMR44-0" or "iC:5060qTMR44-0" or "iC:5060qTMR<4-0". It's also reporting an erroneous size, and the corruption is getting worse the longer the machine has been running for.
I've seen some nearly identical behaviour from the same IDE-CF adapter in my Falcon. It appeared to work reliably with some CF cards and not with others. I never did track down specifically why, and ended up switching to a 2.5" IDE-to-SD adapter instead, and haven't had a single problem since. (Link is to a random vendor for this card. It's a generic Chinese thing, so you can find the same model all over the place.)
The ID example was an actual spinning rust drive.
derkom
Post by derkom »
stephen_usher wrote: Tue Mar 16, 2021 10:19 pm The ID example was an actual spinning rust drive.
Good point, you did say that, didn't you? :lol: Carry on.
Return to “EVERYTHING ELSE”
