Do one at a time. dont try to do them all at once. Which is the hardest to get hold of?Icky wrote: Wed May 27, 2020 9:49 pm Nice board and project @terriblefire.
Wish I had the time to get back onto the Blitter, MMU and GLUE boards we are working on for the ST.
ReAgnus Board (Design Complete)
- Admin sponsor
Re: ReAgnus Board (Design Complete)
You are right doing one at a time is the best option and the Blitter should be the one to finish off first.terriblefire wrote: Wed May 27, 2020 10:07 pmDo one at a time. dont try to do them all at once. Which is the hardest to get hold of?Icky wrote: Wed May 27, 2020 9:49 pm Nice board and project @terriblefire.
Wow, awesome work!
there is no stop to your wizardry! @terriblefire
Longtime arcade collector/repairer. Finally back into Amigaverse!
- Admin sponsor
One of these just popped through my door
I think it might be time for me to offload my supply of Agnus chips I've been hoarding
Maximilian
Nice board!
It's a shame that all those level converters are necessary.
Maybe a two PCB solution would be more preferable?
(Isn't there a connector that you can use that only ads a few mm??)
Count me in if you have a working prototype
Gee wiz, man! He's only just received the blank board! Come on!!!!!!
- 8 Bit Dreams
- Moderator Team
What is this Arana board?
- Admin sponsor
Its a SCSI to SD for my A3000.
- Admin sponsor
So i had a bit of an issue getting the ReAgnus up and running in a toolchain. I ended up adding code to fomu-flash tools to allow it to write to the SPI roms i got from RS.
https://github.com/im-tomu/fomu-flash/pull/10
After that I still had no output from the FPGA even though i had all the tools setup. Then i noticed...
Now i have the FPGA up and i can program it with a Pi.
