The beginning..
Information and progress towards the H5 board.
Re: The beginning..
Everyone is a witness...
DoG
Re: The beginning..
Post by DoG »
Isn't all the fault due to drill distance? Vias or mounting holes intersecting tracks?
EDIT: Should say overlap instead. Hmm...
EDIT2: But you run EAGLE 7 or something?
DoG
Re: The beginning..
Post by DoG »
Aah. Drill distance is when two hole are to close to each other. Vias and holes. Never mind then.
Re: The beginning..
DoG wrote: Thu Oct 29, 2020 10:02 pm Aah. Drill distance is when two hole are to close to each other. Vias and holes. Never mind then.
It was "overlaps" where the problems all were. I was using Eagle 7 and Eagle 9 to check DRC errors.
Re: The beginning..
All I did was move the S2 header, now its magically got 43 wire stubs from before... This is what I mean about Eagle, stuff just doesn't work right :headbang:
Did all those, then ran DRC again, it found another 4 :roll: Did those then found another 2.. Ran DRC serveral times.. nothing..
Restarted Eagle and...
Re: The beginning..
exxos wrote: Thu Oct 29, 2020 11:18 pm This is what I mean about Eagle, stuff just doesn't work right :headbang:
The metaphorical smack on the arse by the midwife that is Eagle, delivering a bouncing baby KiCAD user? ;)
BW.
Return to “H5 Phoenix Platform Edition”
