TF536 Bulk Order (Batch 1 Shipped)
Danoo
Re: TF536 Bulk Order (Batch 1 Closed)
You need more more flux on that noggin so it will flow correctly :D
Life is really simple, but we insist on making it complicated - Confucius
- Admin sponsor
Soldering is a means to an end for me. If i could get the boards fully assembled in the mail I would. It would eliminate some of the potential problems of bringing up a new system.
The last two just arrived, thanks.
And apologies cos I know it'll make you repeat yourself @terriblefire but does the Atari firmware as is fit onto a 144 as well as a 288? Just checking as I have two spare 144s
GadgetUK164
Haha =D I prefer not to solder on small stuff on the underside - so many little components!!!
- Admin sponsor
The basic Atari firmware does.. However once we get the interrupt injection code working expect that to need a 288.PhilC wrote: 11 Jun 2020 17:45 The last two just arrived, thanks.
Thanks for confirming that, I'll keep the 144s for another time then :Dterriblefire wrote: 11 Jun 2020 19:23
carmonster
My board arrived yesterday thanks!!
Forgive me for being a little blind as it seems that I can only see things that are under a microscope these days !!
Where can I find the latest firmware for these boards , ive looked on github/ tf536/ just the rev 1 files are there?
Regards Rich
Regards Rich
- Admin sponsor
https://github.com/terriblefire/terribl ... ster/tf536carmonster wrote: 11 Jun 2020 22:53 My board arrived yesterday thanks!!
Regards Rich
carmonster
terriblefire wrote: 11 Jun 2020 23:36https://github.com/terriblefire/terribl ... ster/tf536carmonster wrote: 11 Jun 2020 22:53 My board arrived yesterday thanks!!
Regards Rich
Thank You!!
katarakt
I figured out some bug in the two BOMs.
In the first post Stephen wrote to complete the build "2. 2 x 10uF 1206 Caps.", but both BOMs (Bom_TF536.csv and Bom_TF536_Buffered.csv) there are 10x 10uF 1206 Caps ?! Should be two to complete populated boards ?
