Random STuff
DoG
Re: Random STuff
Post by DoG »
Woohoo. So nice to have a newly cleaned desoldering gun! Peace of mind. "clean mind.... eeer... clea.. clear.. er... something".
Cleaned desoldering gun.jpg (261.34 KiB) Viewed 3316 times
DoG
Re: Random STuff
Post by DoG »
Got some more Eiffel done. All tested and working.
2022-08-04 16.00.44.jpg (306.36 KiB) Viewed 3272 times
DoG
Re: Random STuff
Post by DoG »
I "needed" an adaptor for an Inventronik ACSI-SCSI board I have. I already done an IDC20-ACSI so I used that as a part of the design to connect to my MegaST. Adapter is a IDC26-IDC20 and a BERG 4-pin connector. But I'm unsure if you could drive the board thru that. It's probably for termination power so I didn't use that and neither should you. But it is there, so deal with it... If you, for some Godforsaken reason, need this, the gerbers and the Eagle files is down below.
Adapter for Inventronik ACSI-SCSI board-Gerbers.zip
(53.67 KiB) Downloaded 131 times
ACSI-SCSI Inventronik EAGLE v9.6.2.zip
(15.01 KiB) Downloaded 83 times
Inventronik IDC26-IDC20 bottom.jpg (107.98 KiB) Viewed 3210 times
DoG
Re: Random STuff
Post by DoG »
Here is it all connected and the speed is not the greatest.
All connected.jpg (556.92 KiB) Viewed 3210 times
BlueSCSI thru a lot of adapters.jpg (442.72 KiB) Viewed 3210 times
DoG
Re: Random STuff
Post by DoG »
I have made and ordered a PCB for C Zietz WiFi/SNTP clock for Atari with DB25 serial port. For fitting in a DB25 shell hopefully.
Wifi-SNTP Clock top.png (38.59 KiB) Viewed 3016 times
Wifi-SNTP Clock bottom.png (44.08 KiB) Viewed 3016 times
I bought some 100ml needle nose flask to have my liquid flux in since I kept tipping the other ones over and spilling it everywhere (Topnik brush flask). I have been using this for a while now. Works great.
Needle nose flask small.jpg (11.31 KiB) Viewed 3016 times
Re: Random STuff
DoG wrote: Thu Nov 10, 2022 10:18 am
[/b]I bought some 100ml needle nose flask to have my liquid flux in since I kept tipping the other ones over and spilling it everywhere (Topnik brush flask). I have been using this for a while now. Works great.
Nice PCBs sir.
I use those bottles for the likes of 3in1 oil (They are a bit handier than the 3in1 bottle)and contact cleaner as the aerosol is a bit too vigorous!!
I haven't tried Topnik in one, I'll give it a whirl, but my preference is for the brush, though I get what you say about knocking it over!!
What I do really like are flux pens with a fibre tip, they're great, and you've just reminded me I need to order a new one :)
DoG
Re: Random STuff
Post by DoG »
Dry fitting seems to be alright in the shell and I can even close it. I don't know if micro USB connector will fit since I don't know where they are at the moment.
EDIT: Apparently I didn't order the USB connectors. I wish I had made the board 1mm longer as well, but hopefully it will work anyway. Maybe a v1.2 perhaps. :D
2022-11-28 16.29.42.jpg (319.35 KiB) Viewed 2942 times
DoG
Re: Random STuff
Post by DoG »
Soldered one of the Wifi/SNTP-clock boards for testing and everything seems to line up rather nice. The USB connector wasn't lined up with the hole all the time since the PCB was a bit loose inside the case. The solution right now is a piece of thick paper to prop it up a bit. Oh, and the hardware works with the software to get the current time of course.
DoG
Re: Random STuff
Post by DoG »
I soldered the last bits on a BlueSCSI v2 (programmed the Pico as well of course) and tested on a remake board. I used the Inventronik adapter in between so it's probably/maybe it that drags the speed down since BlueSCSI v2 can go faster.
DoG
Re: Random STuff
Post by DoG »
Soldered and programmed a Cubase Audio Dual Dongle.
cubase dual dongle DoG small.jpg (55.44 KiB) Viewed 2249 times
