Now you say...
So has pin 16 been deliberately lifted, or a broken via ?Acsi wrote: Sun May 03, 2020 10:09 am Currently Pin 16 of the 030 isn't connected to anything and pin 17 which is also lifted is connected to the Afterburners wiring loom.
I don't know how AB fits, so you probably best looking at the install manual as to what is done to the falcon and whats not. I know some pins on the CPU were lifted on the CPU for some reason, maybe tied to a power rail to disable the CPU most likely, but pins should never by left floating.
Though I would suggest if the DMA has been overclocked, along with any chips, you start putting stuff back towards a stock machine.
