Module ESP8266 without TF on Amiga
kulamario
Re: Module ESP8266 without TF on Amiga
Post by kulamario »
I setup for 9600 ping from linux go but from amiga no
kulamario wrote: Mon Apr 20, 2020 3:26 am I setup for 9600 ping from linux go but from amiga no
Edit the install_script, replace the 115200 (or 38400 if you've edited it already) to 9600 and rerun the script. Then reboot the amiga. If you still have issues after that its your hardware thats the issue.
dalek
Post by dalek »
kulamario wrote: Thu Apr 16, 2020 9:22 am I try to setup like on picture
In your picture (on page 2) it is not clear but it looks to me like you have TX pin 2 -> TX pin 2 and RX pin 3 to RX pin 3 on your DB25<>DB9 connection, but you need to cross them over - TX to RX and RX to TX.
kulamario
Post by kulamario »
exactly i done this
when it comes to the adapter on the DB9 side we connect Amiga yes?
ESP8266 to Amiga2.png (388.48 KiB) Viewed 6133 times
Can you please verify your hardware works by talking to raspberry pi serial port GPIO or something similar.
In general this thread is looking like a technical support disaster and is going to get cleaned up or removed soon.
@kulamario Everyone on the forum is more than happy to help but this is your project you've wandered off the well beaten path and you need to own it.
kulamario
Post by kulamario »
No have raspberry I have only arduino but I check today this converter
I connect to one side usb to rs232 converter on second side I short tx to rx in terminal I have communication
So I think this converter work fine
Next what I think maybe burn diagrom and check serial port in amiga ?
I hope is not broken
theq
Post by theq »
kulamario wrote: Mon Apr 20, 2020 3:19 pm Next what I think maybe burn diagrom and check serial port in amiga ?
You can download and use AmigaTestKit, and build a serial dongle to test it. Same dongle DiagROM uses.
kulamario
Post by kulamario »
I check this on putty I have something
And amiga test kit show like is something wrong I think
theq
Post by theq »
kulamario wrote: Mon Apr 20, 2020 3:40 pm I check this on putty I have something
You have made a dongle with the required bridges?
kulamario
Post by kulamario »
No just connect to PC via RS232 to usb
Locked
