Module ESP8266 without TF on Amiga
Locked
Re: Module ESP8266 without TF on Amiga
set bitrate 38400
save
reset
kulamario
Post by kulamario »
I waiting maybe few minutes with
CMD>reset
Then I get info
Connection closed by foreign host.
So I write agin
telnet 192.168.240.1 7777
Then
set bitrate 38400
save
reset
After reset is still freeze CMD>reset
kulamario wrote: Fri Apr 17, 2020 5:16 pm I waiting maybe few minutes with
CMD>reset
Then I get info
So I write agin
Then
set bitrate 38400
save
reset
You are all set. Plug it into the amiga and use my script.
kulamario
Post by kulamario »
This script how to start ?
Just double click and then enter , enter ... ?
kulamario wrote: Fri Apr 17, 2020 5:18 pm This script how to start ?
type execute install_script
Check that the version is the one with the baud rate of 38400.. the one i posted on this forum has that baud rate.
theq
Post by theq »
Just power off and on the ESP after reset. Should make it work.
kulamario
Post by kulamario »
How to check this ?
I disconnect esp8266 from laptop and connect to amiga
Install your script
I try to open site in AmiiFTP and nothing happened
How should be Led on esp8266?
My just light up for 2sec and then turn off
kulamario wrote: Fri Apr 17, 2020 5:45 pm How to check this ?
Install your script
start with ping 192.168.240.1 at a cli after a reboot.
kulamario
Post by kulamario »
No working
kulamario wrote: Fri Apr 17, 2020 6:03 pmNo working
Have you tested your hardware?
Locked
