Module ESP8266 without TF on Amiga
matt020
Re: Module ESP8266 without TF on Amiga
Post by matt020 »
For Windows, use software "NodeMCU" to flash the ESP8266
There are videos on YouTube on how to do it.
That will flash the ESP, but now you need to telnet in on port 7777 to the ESP8266 to set wifi SSID and wifi password to suit your network. I haven't received my ESP8266 so I haven't got that far yet......
matt020 wrote: Fri Apr 17, 2020 12:31 am That will flash the ESP, but now you need to telnet in on port 7777 to the ESP8266 to set wifi SSID and wifi password to suit your network. I haven't received my ESP8266 so I haven't got that far yet......
There doesnt appear to be a way to slattach via windows. At least that i know of .
kulamario
Post by kulamario »
I download Ubuntu
Can I do everything from usb stick or I must install Ubuntu?
What I should to do next ?
Please help me
Like I said I never use linux
kulamario wrote: Fri Apr 17, 2020 10:38 am I download Ubuntu
Please help me
try ...
sudo slattach
if not installed try
sudo apt-get update
sudo apt-get install net-tools
sudo slattach
Plug the esp with the firmware into a usb port...
sudo dmesg
it will list towards the end which is the name of the serial port. it will be like /dev/ttyUSB0 etc.
then follow the guide.
kulamario
Post by kulamario »
I get some error
kulamario wrote: Fri Apr 17, 2020 2:19 pm I get some error
Do what it says then.
kulamario
Post by kulamario »
I found solution
Just write
sudo dpkg --configure -a
I install all of this
sudo apt-get update
sudo sudo dmesg
Then start do this
sudo slattach -L -p slip -s 115200 /dev/ttyUSB0&
And after this
sudo ifconfig sl0 192.168.240.2 pointopoint 192.168.240.1 up mtu 1500
is some error like on picture
let me google...
type sudo ifconfig -a
dalek
Post by dalek »
You wrote s10 not sl0.
Letter 'l' not number '1'. sl0 stands for 'slip interface 0'
kulamario
Post by kulamario »
Ok done but dnt know what is going on
After CMD>reset
Nothing happened just start blink LED on esp8266 few times
And now blink every maybe 2-3 minutes
In terminal is still like on picture
I check on my router what devices is connect
I have ESP_07CF0D_Wireless
Locked
