Module ESP8266 without TF on Amiga
matt020
Re: Module ESP8266 without TF on Amiga
Post by matt020 »
kulamario wrote: 15 Apr 2020 15:20 Yesterday i got adapter
Does that adapter convert 12v signal from the Amiga to 3.3v for the ESP8266?
kulamario
Post by kulamario »
I think so I power this 3.3v so should be
I have question about esp8266 speed
What baudrate I should set up ?and what mode ?
dalek
Post by dalek »
Hey, I like your idea of an all-in-one pcb with a DB25 connector. It would be handy to have along with a network boot disk to jumpstart any old system. I don't like the idea of extra cables sticking out.
But you'll need to add a jumper/switch for programming the chip - I think for the one you've selected it's GPIO0 to put it in programming mode, along with the reset button.
And you should connect up all the grounds on your DB25 connector (missing in your schematic and PCB).
matt020
Post by matt020 »
I'm no expert, but I'm still concerned about the 12v <--> 3.3v side of it.
kulamario
Post by kulamario »
dalek
I agree, need to add a jumper on GPIO-0 to GND
I was also thinking about adding a link to esp8266-01
matt020
you can't have 12V on the output because MAX3232 is powered by 3.3V after that the maximum voltage for max3232 is 5V
so you definitely have the TTL standard output
matt020
Post by matt020 »
What is the voltage on the Amiga serial port TX line?
kulamario
Post by kulamario »
On amiga I think is 12V
matt020
Post by matt020 »
kulamario wrote: 16 Apr 2020 03:34 On amiga I think is 12V
Does the serial to TTL adapter lower the voltage from 12v to 3.3 for the ESP8266 module?
kulamario
Post by kulamario »
Yes exactly this module change for 3.3V
dalek
Post by dalek »
matt020 wrote: 16 Apr 2020 03:33 What is the voltage on the Amiga serial port TX line?
No, it's 5V per schematics.
Users browsing this forum: Bing [Bot], CCBot, Qwantbot and 2 guests
