Which bits are missing on the DB23? it has the same pinout as the kipper2k riser just routed to the A?_EXT pins.8 Bit Dreams wrote: 07 Jan 2021 15:50 Thre are some discussions on A1k, people are very interested, we'll need some tweaks to get it work with D520 though cause DB23 isn't fully routed..
TF CD32 Riser Revision 2 Design Complete
- Admin sponsor
Re: TF CD32 Riser Revision 2 Design Complete
Amifun
Very impressive work :D
If testers are needed I can try(receive a board, assembled or not) albeight I have no programming knowledge
Kai
Norway
Kai
Norway
- Admin sponsor
OK so this is the wrong riser for them! Like most things on a1k they miss the point of the design....8 Bit Dreams wrote: 07 Jan 2021 15:50 Looks nice!
is this the final version or some updates/optimisations will follow?
Thinking about to get small batch of them..
This risers video is designed to let me use FMV output on DB23. So if you want the digital outputs direct from LISA then you will not get FMV. I prefer to see my FMV output on my DB23 than have 100% perfect video.
Honestly i have no interest in what people on a1k want as they have been nothing but rude about me over the years.
alenppc
- Moderator Team
What exactly is D520? All I know of is the Commodore A520.
kulamario
I think they talking about this
https://d520-converter.de/produkt/d520-converter/
arkadiusz.makarenko
- Moderator Team
It is open design anyone can modify it to own needs if they wish. If signals are on edge connector then it should be easy enough.
My personal opinion on this is that I don't own this device, and I am not planning to buy one, so it is not something I am interested in supporting. I am more than happy with quality of my £5 gumtree grab TV with SCART input.
~ Stanislaw Lem
~ Stanislaw Lem
kulamario
the honest truthI am more than happy with quality of my £5 gumtree grab TV with SCART input.
arkadiusz.makarenko
- Moderator Team
I have prepared new firmware
1. non blocking keyboard routine
2. Memory setting optimization, which do help tiny little bit with performance.
https://github.com/arkadiuszmakarenko/T ... r_binaries
~ Stanislaw Lem
~ Stanislaw Lem
- Admin sponsor
Will give it a go
RetroFletch
EDIT: arkadiusz.makarenko was kind enough to answear my questions in PM so i removed them from here
Anyways, im happy to see so much effort going into this i probably spent way to much time rading thru this thread, keep up the good work!
Users browsing this forum: CCBot and 7 guests
