terriblefire wrote: 18 Dec 2020 21:26
what you missing?
Main bit connectors. Mouser started moving my order, so there is still a chance.
I should have ordered it long time ago...
i'll send you two with my board.
arkadiusz.makarenko wrote: 25 Dec 2020 23:14
I have ordered PCBs, so I am planning to make some prototypes.
Apologies. Wife fell over and broke her ankle before xmas so have had zero time.
Shit. I hope it was not serious fracture?
I can't reply to your PM. But I will do it what you asked me.
PS.
I need to do few boards and test them on my CD32, and check if it behaves the same on different machines. So I though that I would build few test risers, and give some away to people who can do some troubleshooting for me in case of issues.
~ Stanislaw Lem
arkadiusz.makarenko wrote: 29 Dec 2020 21:34
PS.
Its not bad but in a cast thing.
Do you have a binary for the rev 1 riser i can flash? i was going to look at the CD32 again maybe in the new year .
PS.
I have introduced 1 us delay at the end of irq handling in this one, as occasionally Amiga didn't boot without delay. It is 1us as I have it done for other things, and going sub 1us is a little bit tricky (will look at this if this firmware will boot and work on various cd32s)
~ Stanislaw Lem
Will that work on the previous version of the board?
I don't think so. Keyboard and control signals changed pins.
Ok.. I only have rev 1 built right now. Rev 2 still staring at me...
Rev 0 in bin. Will this firmware work on rev 1.. (because filename says rev1).
