TF CD32 Riser Revision 2 Design Complete
TF CD32 Riser
arkadiusz.makarenko
Re: TF CD32 Riser Revision 2 Design Complete
Post by arkadiusz.makarenko »
terriblefire wrote: Fri Oct 16, 2020 4:25 pm
arkadiusz.makarenko wrote: Fri Oct 16, 2020 4:06 pm Still have some bug in verilog, as I still clash with tf330 somwhere.
Run the complete memory detection in diagrom to see issues.
Diagrom sends rtc interrupt during memory detection (A3000/4000) (at diagrom boot).
How can I check if I clash with higher addresses?
Can you see anything obvious here ?
wire rtc_decode = A[23:16] == 8'b1101_1100;
wire rtc_int = PUNT_IN & rtc_decode ;
assign PUNT_OUT = PUNT_IN ? (rtc_decode ? 1'b0 : 1'bz) : 1'b0;
assign INTSIG2 = rtc_int;
assign DSACK = rtc_int?(INTSIG7?2'b10:2'b11):2'bzz ;
assign INTSIG3 = A[3];
assign INTSIG5 = A[5];
~ Stanislaw Lem
clock these guys or you'll get logic hazards.
https://en.wikipedia.org/wiki/Hazard_(logic)
Put at least rtc_int in an always block...
otherwise any glitch will trigger an interrupt.
always @(posedge CLKCPU_A) begin
	rtc_int <= ...;
end
using assign's and combi logic is asking for trouble.
Also your arm code should check the interrupt is still pending before responding.
arkadiusz.makarenko
:facepalm:
I should read what is written on the screen, and hold bloody left mouse button when it says to do it if it hangs :D
Saying that adding always and additional check on int signal on arm side, now ram test is successful, workbench boots and clock reads RTC (early days).
Second time I was obsessing about really non issues.
~ Stanislaw Lem
matt020
Post by matt020 »
Just a quick post from someone who is following this thread with amazement. Such good progress! Keep it up!!
wairnair
Post by wairnair »
matt020 wrote: Sat Oct 17, 2020 2:16 am Just a quick post from someone who is following this thread with amazement. Such good progress! Keep it up!!
same here!
arkadiusz.makarenko
Rtc now can be detected by ATK as msm6242 :)
Just need to complete setting date and that would be easy stuff more or less ready.
Edit:
Default date need to change... I can't face living in 2020 all the time ;)
~ Stanislaw Lem
Sweet.
arkadiusz.makarenko
Ok
Writes and reads implemented. I may need to add support for sleep mode and restore after wakeup (Need to wait for new board), but at this point I have done what I could. :)
I have created binaries repository
https://github.com/arkadiuszmakarenko/T ... naries.git
CPLD source code: https://github.com/arkadiuszmakarenko/T ... v1XC9572XL
STM32f722 (still can fit in stm32f730) - https://github.com/arkadiuszmakarenko/TFRiserRev1F722
Time for a bottle of wine.
~ Stanislaw Lem
arkadiusz.makarenko wrote: Sat Oct 17, 2020 8:58 pm CPLD source code: https://github.com/arkadiuszmakarenko/T ... v1XC9572XL
boards are 80% done manufacturing.
We have keyboard and mouse support? :)
Return to “TF CD32 Riser”
