TF CD32 Riser Revision 2 Design Complete
TF CD32 Riser
Re: TF CD32 Riser Revision 2 Design Complete
arkadiusz.makarenko wrote: Fri Oct 16, 2020 10:12 am Do you think that bad RTC output can crash booting to Workbench?
Unlikely i would say its more likely some weirdness happening when TF330 uses fastmem.
arkadiusz.makarenko
Post by arkadiusz.makarenko »
terriblefire wrote: Fri Oct 16, 2020 11:02 am
Forgot about that TF330 can introduce those issues.
Is there anyway to detect this? Like by checking PUNT?
~ Stanislaw Lem
arkadiusz.makarenko wrote: Fri Oct 16, 2020 12:00 pm
There is a PUNT IN from the expansion slot. the CPLD should shut up when it sees this asserted and not decode.
This is why i split PUNT_IN and PUNT_OUT. Its why the Analogic risers dont work well.
arkadiusz.makarenko
terriblefire wrote: Fri Oct 16, 2020 12:19 pm
I will add this, and lets see what will happen. :)
~ Stanislaw Lem
arkadiusz.makarenko wrote: Fri Oct 16, 2020 2:09 pm
If something like this is not present then any attempt to access 40bfe001 will cause both the ARM and the SDRAM to respond. etc
arkadiusz.makarenko
terriblefire wrote: Fri Oct 16, 2020 2:29 pm
It did! Thank you. Boots every time now.
I was again barking at wrong tree.
I had to get my head round verilog to combine both states. Still some date/time is not read correctly. I need to do better job in translating values of arm RTC to what Amiga expects (boring, and time consuming staff).
But it is time to slowly start looking at mouse support?
!Message from: Moderator
@arkadiusz.makarenko, we have placed your attachments in-line so they display correctly in your post. Here's the how-to guide.
~ Stanislaw Lem
arkadiusz.makarenko wrote: Fri Oct 16, 2020 3:41 pm
Yeah i would do mouse next because issues will show up fast.
arkadiusz.makarenko
terriblefire wrote: Fri Oct 16, 2020 3:48 pm
Still have some bug in verilog, as I still clash with tf330 somwhere.
~ Stanislaw Lem
chucky
Post by chucky »
yes that have happend
arkadiusz.makarenko wrote: Fri Oct 16, 2020 4:06 pm Still have some bug in verilog, as I still clash with tf330 somwhere.
Run the complete memory detection in diagrom to see issues.
Return to “TF CD32 Riser”
